OctaneRender® for ArchiCAD beta - build 1.11b [OBSOLETE]
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
rappet
face_off wrote:I tried batch rendering in ArchiCAD (via setting the View "Generate In" to "Photorender Window", and then setting all the views to shortcuts to publishing set - as per http://www.youtube.com/watch?v=tluXEVPayYI), however when I publish the set, it changes the Photorenderer from "OctaneRender Renderer" back to "Internal Renderer". Is this an ArchiCAD bug?
Hi Paul,
I got the batch render working perfectly.
you can see my workflow, maybe you can spot something you are doing different?
cheers, Jeroen
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
Thanks Jeroen
1) What build of ArchiCAD are you on?
2) Does this mean the plugin doesn't need a batch renderer (since ArchiCAD provides the functionality anyway)?
rappet
face_off wrote:Thanks Jeroen
Hi Paul,
My AC build is 3487 (just adjusted in my signature).
The AC batchrender works great as it is, but (if I am not wrong?) in combination with the OR plugin it is not possible to have different settings.
For example: I can not have one viewmap rendered with environment daylight and the other environment
with hdri background by using texture environment. Or i.e. when using a focus with aperture it works in one view, but everything might be unintentional blurry using the same settings.
If I am right the OR settings are the same for all viewmaps, so the use of Batchrender in AC without OR settings linked to the viewmap, the use of batchrender AC is great, but limited to setting difference in rendersize.
greetings, Jeroen
Thanks Jeroen - I'll update my AC16 to the same build as yours and see if it rectifies the issue.
In theory, the next release of the plugin will address the issue of batch rendering with different rendertarget settings for each image. However, I now know not to makes assumptions like this until it's actually working :-)
I hope to have the next release done today. Adding the rendertarget for each view has been massively more complex than it should have been, so apologies for the delay.
rappet
face_off wrote:New version posted - pls see http://render.otoy.com/forum/viewtopic.php?f=56&t=30246.
Super!
Too bad for me I just found out being away from PC.. Looking forward to enjoy new version.
Greetz
rappet
Hi Paul,
In 1.11b3 when enlarging the number maxsamples the rendering starts from scratch instead of continuing :D
greetings, Jeroen
Thanks Jeroen
Looks like it's only restarting if it's hit the maxsamples already. I'll fix this in the next patch/release.
maxhenli
hi,
i just bought the plugin for archicad on the frontpage.
now i realized, that there is no version for mac.
do you plan to build one?
regards bernhard
Yes, I am starting work on the Mac version in the next few weeks. In theory all the plugin source code will compile without modification on the Mac.
Return to “Graphisoft ArchiCAD”
