Nice result. If I understand well, these clouds require heavy geometry ? If I want to add this kind of clouds to an already heavy scene close th the VRAM limit, I can't.
I expected clouds to use the fog medium and being shaped procedurally inside a low poly count volume. Is it possible ? I haven't achieved a decent result so far.
Clouds
Thanks, here is the model version of the cirrius, Bepeg :
The clouds are some time very high poly, between 100 000 and 1 million polys.
If you don't have to turn around, you can use a low poly model with a texture, the result could be not too bad, I haven't tried it yet.
Somet other multiple clouds :
wow, the backlight versions are awesome, thanks
ciao beppe
ciao beppe
Wow, cesar this is top notch.
- BKEicholtz
+1 Easy cloud generation would be an awesome/needed addition to Octanes excellent sun/sky system!gabrielefx wrote:well done!
puffy clouds are perfect!
collaborate with Karba and implement your materials to be applied to atmospherical gizmos.
ASRock Extreme11 | i7 3970x 5.0 Ghz | 32gb RAM | (4) EVGA SC Titans
+1 on sharing the material...
SEHSUCHT Berlin - 22x GTX 780
Here is a sample scene.
I principally edit the scale of the scattering node and the scattering_direction value.
- Nuage.rar
- (2.14 MiB) Downloaded 473 times
merci ça peut servir.
