Beta 0.3.4 released (Old version)
datee
Beta 0.3 works fine, but beta 0.3.4 gives me the error message "OCTANE API ERROR:CUDA device 0: Failed to find a CUDA binary matching compute model 2.0" when c4d starts up...
...why?
mauricesteenbergen
datee wrote:Beta 0.3 works fine, but beta 0.3.4 gives me the error message "OCTANE API ERROR:CUDA device 0: Failed to find a CUDA binary matching compute model 2.0" when c4d starts up...
...why?
I got this too, 0.34 is not working for me, spent past hour trying to get it to work. Going back to 0.3 and await next stable.
Render: Geforce GTX480 (EVGA) (1.5GB) | OC @ 1.0V / 750Mhz
Display: Geforce 8800GT (NVIDIA) (512MB)
OS: Win 7 x64 | CPU: Quad Intel Xeon 2.66GHz (12GB)
attusind
Hi Aoktar
I had a blue screen right now! :(
It's not the first time I had this problem; It's also happened with 0.30 release.
I've attached a window's print screen with problems informations (sorry it's in italian)
I've also attched the zip file of cinema 4d's bg report.
I hope it's enough for you to understand what's the problem.
Thank you
_BugReport.zip
(24.02 KiB) Downloaded 235 times
Asus Z97-WS | i7 4790k 4.0 Ghz | 32 GB ram | Quadro 600 | 3x GTX 980| Win 7 64 bit | nvidia 344.75 | Cinema 4D R16 | OctaneRender™ for Cinema 4D 2.23.2 RC3
http://www.attu.it
mauricesteenbergen
I can't redownload the previous version 0.3 and I've overwritten with the 0.34. Can I redownload the previous version somewhere? Right now it's kinda messy with all the different topics and only the latest in the download area.
i have sended you. Are you check with english version of Cinema 4D?
mauricesteenbergen
aoktar wrote:i have sended you. Are you check with english version of Cinema 4D?
Thank you, yes English version.
0.3 was fine, 0.34 gives same error as user above posted (the one about suitable GPU not found)
lilbignik
Hi Ahmet. Thank you for your work. I like it! But i really want to see some improvement in material editor.
First it is support cinema procedural map (and layer, filter etc.) I use it in every project, therefor i can't render in octane all my old scene. It is really bad.
Second, i can't understand why in material editor we see all settings of every type material. I think we don't need to see it, for example, specular chanel in diffuse mat. and why we have so a lot of activated ticks in default mat? I don't need it.
Hope to see this important improvements in future releases. Thx.
Sorry for my English
Win 10 x64 / amd fx-9590 5.0Ghz / 3xGTX Titan Black 6gb/ 32gb / ArchiСad 19 / Cinema4D R17 / latest Octane.
lilbignik wrote:Hi Ahmet. Thank you for your work. I like it! But i really want to see some improvement in material editor.
Octane only support own texture types
are you saying pointed checkboxes?
NVN
how to get a "SSS" effect?
Which channel is it??
I see "scattering medium" but where i have to drag in?
lilbignik
Yes. I mean pointed checkboxes. Didn't know how it in english. :)
Why they are there? I don't want to see specular, transmission, roughness, reflection....in diffuse mat. i think it is confusing users. And why they are activated in default. if I need i will activate it myself.
You mean it is not possible to support all cinema texture type? I don't need so cinema procedural map, like noise, gradients or some surfaces. But i really need filter and layer. It is very poverfull tools.
