OctaneRender™ for Cinema 4D released
~abreukers: please read new my PM message.
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
NEW ViewSonic XG2431 24"
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
Next thing (also minor) :
When using Function > Remove unused materials from the material manager menu, materials in an Octane mix material are not protected. For example, the mix material is applied to a glass sculpture but neither of the 2 materials in the mix material are directly applied to anything. So they are removed by the command. This is a very frequently used command for scene management so it would be good if eventually, the mix materials could be protected.
similar to vray materials. I'll add custom command for this issuedecade wrote:Next thing (also minor) :
- EricDesign
- Contact:
Work perfect thx
just one thing if you save your layout and re-open cinema4d the windows where you place your octane windows mark as missing pluging.
look my screen shot. and you need some time to render all texture for the rest is work fine
looks nice so far, but I have some major problems:
When I add a daylight, I cannot adjust the hight of the sun
and when I try the other method with c4d-sun-tag the changes
does not seam to work.
Also, If I add any new environment (texture or daylight) I loose
my textures. The sphere f.e. had a texture-material applied.
Any tips on this?
thanks
Mike
And when I quit C4D I get 3 or 4 "API"-Errors and C4D crashes!
Any tips on this?
thanks
Mike
- Silverwing
- Contact:
As I understand it there is no rendertime option. Instead you can set the desired samples per pixel.datee wrote:How do you set the desired rendertime pr frame when rendering an animation?
You will get varying rendertimes but the noise ratio stays the same throughout the rendering.
If it was possible to restrict the renderer to a certain rendertime and some parts of your animations need longer to clear up (because of more complex calculations) in the final rendered animation you would see more noise in those frames than in the others (that were easyer to calculate) and that would look strange in my opinion.
Just adjust the sample rate so you get about the render time you want!
Cheers,
Silverwing
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
- indexofrefraction
... that would be something vrayforc4d didnt manage to do for yearsaoktar wrote:similar to vray materials. I'll add custom command for this issuedecade wrote:Next thing (also minor) :
the problem can be easily circumvented by dropping the used mats on an empty null object.
the "remove duplicate materials" command is more important to work properly,
(if it doesnt already)... with vrayforc4d there was the issue that when copying stuff to and back through different
files, you ended up with duplicate materials that couldnt be removed with "remove duplicate materials",
that's more annoying.
but these things are not really priority issues i think
much more important are material mapping things like
support of all projection modes, selection tags, mix materials, tiling, etc
Mac Pro (2012) 2x6 Core | 24GB | 1 x Geforce GTX580/3GB
there is no mapping types on Octane. All mappings are converting to uvmapping before rendering. also selection tag is working.
what is the problem? if you post on c4d forum, will help
Also for daylight problem. if you place manually suntag will work. some object presets need revision
