OctaneRender® for 3ds max® v1.11c[Test] UPDATED(14March)
profbetis
I also found some bugs (both related to the new fake_shadows/Octane Fog algorithm).
1. Incorrect Illumination inside volume
First: here is a scene with a fog volume showing correct radiosity from the sun hitting the objects. Objects are colored red, glossy, IOR = 2, reflection set at 1.0
Second: here is the same scene with Objects (still colored red), glossy, IOR < 1, with reflection set at 1.0
Somehow the red color is being reflected even though the object doesn't have a "color" anymore because of the reflection properties.
Third: here is the same scene as above, with the fog volume removed, showing correct lighting.
2. Aperture of camera affects fog visibility
First: here is a scene with the aperture (using octane camera) set at 0
Second: same scene with aperture set at 3; not much of a difference, but still odd.
Third: same scene again with aperture set at 20; can hardly see the fog at all.
GTX 1080Ti 11GB (3x), Water-cooled
Intel i7-5820K 6-core @ 3.3GHz
Windows 10 Pro 64-bit, 32GB RAM
Karba
profbetis wrote:I also found some bugs (both related to the new fake_shadows/Octane Fog algorithm).
What kernel do you use Direct Lighting?
With path tracing and PMC it should work fine.
Regarding camera aperture. How Do you set fog volume? By small plane before camera? very likely that aperture disk is out of that small plane or it get inside of volume geometry.
Karba
What kernel do you use? Direct Lighting?
If not, what depth do you use?
User avatar (Default)
merid888
thank you karba i'll proof and i'll comment
profbetis
@Karba: This was in PMC mode at depth 8, higher does bring in more white, but the problem persists.
I have attached the scene file in a zip.
FogTests.zip
(28.07 KiB) Downloaded 247 times
merid888
well, how i can create the fog for an interior ???
thank you if some one can share setting and how apply
regards
Karba
version 1.11b is updated to 1.11c
3ds max® 2010: http://www.refractivesoftware.com/plugi ... v1.11c.zip (50MB ZIP File)
3ds max® 2011: http://www.refractivesoftware.com/plugi ... v1.11c.zip (50MB ZIP File)
3ds max® 2012: http://www.refractivesoftware.com/plugi ... v1.11c.zip (50MB ZIP File)
3ds max® 2013: http://www.refractivesoftware.com/plugi ... v1.11c.zip (50MB ZIP File)
Carl S.
I love the pace of the updates, great work. Thank You.
snake12
Hi, profbetis thanks for your scene, the problem you have is the box with material fog is must to be more bigger than walls and ceiling.
Hi Karba but I found a bug, when change the saturation in this versión 1.11c change only the bright and turns more White, I think like the other versión, all render lost saturation. See the render A have saturation 1.0 the render B have saturation .9
This is similiar a saturation to white.
Cosmos II, Asrock 79 extreme 11, Intel i7-3930K 4.40 GHz, 32gb Ram Quad 2.400 OC., 2 Drives Intel SSd 520 240gb Raid 0, 1 Gtx 580 3 gb + 3 Gtx 590 4Gb.
oguzbir
Thank you very much Karba for the updates..
Cheers
My Portfolio
Return to “Autodesk 3Ds Max”
