OctaneRender® for 3ds max® v1.11c[Test] UPDATED(14March)
Karba
BUG FIXES SINCE LAST RELEASE:
  • crash with mesh updating
  • crash with material with dirt texture preview
  • hot pixels in case of alpha shadows + environment importance sampling
This version requires video driver 301.42 or higher.
Limitations on old cards
The PMC kernel and the matte material options don't work on old graphics cards (GTX 2xx, compute model < 2.0).
DOWNLOAD
We have 4 separate archives available for download, for Autodesk® 3ds max® 2010, 2011, 2012 and 2013.
Each archive contains the manual and installation text file, and both 32bit and x64 versions of the plugin,
so you only need to download one archive for your 3ds max® version from the following download links:
version 1.11b is updated to 1.11c
3ds max® 2010: http://www.refractivesoftware.com/plugi ... v1.11c.zip (50MB ZIP File)
3ds max® 2011: http://www.refractivesoftware.com/plugi ... v1.11c.zip (50MB ZIP File)
3ds max® 2012: http://www.refractivesoftware.com/plugi ... v1.11c.zip (50MB ZIP File)
3ds max® 2013: http://www.refractivesoftware.com/plugi ... v1.11c.zip (50MB ZIP File)
Yours,
The OctaneRender® Team.
JuM
Thanks Karba.
Elvissuperstar007
thank you!))
JJTTBB
Thanks! Great to have quick updates... this makes the difference to the customers...
AutoCAD,Revit Architecture, Max Design (all 2012) , Moi3D,Maxwell Render,Octane Render
Intel i7-8Gb RAM - Win7x64 - GTX550Ti
3rdeye
great..thx for the update !!
wisemanxxx
Thank you for this very quick update.
And I want to ask a question ; any chance to use max' standart output map in future updates? Especially working with HDR images I really need it. I posted some example images what can an output map do without using photoshop for tweaking HDR images;
http://render.otoy.com/forum/viewtopic.php?f=27&t=26236
lixai
@Karba did you consider implementing Vertex Color ? it is very useful for vegetation.
Here is a nice article about this, since textures are a problem, this is a good solution. http://bertrand-benoit.com/blog/2012/10 ... tone-tree/
Core i7 860, ZOTAC GTX 580 - 3GB, 2 x GTX TITAN, 32Gb RAM
vk3d
Bug with camera clip
Dual Xeon E5520 2.27 GHz, 48 GB DDR III
3ds Max 2016x64, Octane render for MAX, Titan Z
cfrank78
Working for 3 hours now. Did some tests. Not one crash and everything works as it should as far as i saw!
Great Work Karba!
The only thing i found out is, that if you have the material editor box open, the whole interface is completely slowing down. I really do not know if thats a 1.11b or a octane itself problem, but it is anyway not a big deal. As soon as i close the Material Editor its fast and responsive again!
Thanks Karba!
JulioCayetano
I´m afraid that I´m experiencing the same crashes as before with 1.11a. Randomly, when I´m reloading the scene in Octane´s viewport 3Dsmax crashes, and my scene is lost :cry: . I´m testing with two different scenes, in the first one I´m using DIRT texture, but in the second I don´t. Max is crashing in both of them. So I suppose that it has nothing to be with DIRT.
Hope this info will be useful for devs. Thank you very much for your effort.
MoBo: Gigabyte X58A-UD3R // CPU: i7-930 // RAM: Kingston 12gb DDR3 // Display GPU: GTX 480 1,5gb + Rendering only GPU: Gigabyte GTX 670 4gb.
Return to “Autodesk 3Ds Max”
