Rounded edges.
The renderer geometry in the scene for a 90 degree threshold, if detected it rounds the geometry according to a user specified amount. Blender does it with geometry at render time I believe, Mental Ray does it similarly, modo does this via the shader--I haven't touched V-Ray in a while so I can't speak for that renderer. It is possible with RenderMan but due to the nature of how that renderer is built, it requires a specific shader written for certain types of geometry. The easiest implementation i've seen of this yet, is in modo.
Rounded edges in modo: http://www.luxology.com/training/video.aspx?id=631
I believe this feature alone would bring many folks to Octane. :O
Mikel
Feature Request: Rounded Edges
yes!!
GTX 1080Ti 11GB (3x), Water-cooled
Intel i7-5820K 6-core @ 3.3GHz
Windows 10 Pro 64-bit, 32GB RAM
neat stuff =) definatelly worth to get a place in any engine. Yeah, that could be done manually, modeling all this, but..it takes a lot of time..inplementation of this feature through shaders might be a great time saver..Subtle, but brings that extra somehing for the output =) one day I love to see that in Octane too.
- theCreativeMind
- Contact:
+1
That shader would be a great addition to octane's feature set.
iMac 27" | OSX 10.8.2 | Nvidia GTX 680mx 2GB | Core [email protected] GHz | 32GB
vis4arch.architecture.cad.design.illustration.3d.visualization.photo montage.animation
- JulioCayetano
Yea +1 for that shader! That should be a extreme time-saver shader.
MoBo: Gigabyte X58A-UD3R // CPU: i7-930 // RAM: Kingston 12gb DDR3 // Display GPU: GTX 480 1,5gb + Rendering only GPU: Gigabyte GTX 670 4gb.
+1
Yes this is a necessity in a modern renderer. As I said in the other request post. It is also very useful for simulating water surface tension against a object. If you look at the edge of water meeting a wall there is a rounded edge. In Mental Ray you enable "round corners" in the Arch&design shader, and enable "blend with other materials".
Also good for eyes, to get that little white highlight where the eye meets the eyelid.
OH Yes I want it too.
Perhaps an edge texture in the bump slot would make it... just an idea
