script for Modo( data from instances to Octane scatter)
enverholancev
Yes i think it don't work at all with rotation) modo has different matrix, need to understand relations between them.
enverholancev
Uploaded new one on first post with rotation fix. Seems it works.
funk
Good stuff! The fix works.
UPDATE: I thought there was another bug, but after more testing it seems to work fine. I'm not sure why I was getting an extra instance before
Thanks for the script :)
enverholancev
Script grabs position of meshes, locators, lights etc. You might accidentally select folder too.
enverholancev
Little trick:
You can export Area Lights by changing their size by scale(important),but not by width and height parameters. Stay to default 1m to 1m.
Then you should create mesh similar to light size(1m to 1m).
Select lights and export data through script.
fatrobotsneedlove
Worked great. Thanks so much!!
4x 2080ti hybrids, 4x 980ti Hyrbids. C4D, Houdini.
Return to “Foundry Modo”
