Batch Render -- different issues?
Moderator: JimStar
johnb4467
Hi everyone,
I saw a thread with issues regarding the batch render function not working, but I don't seem to be having the same issues error-message wise.
Truthfully, I may just not be setting it up correctly...but I'm not doing anything differently than I would for another render engine, I don't believe.
Anyway, I'm in maya 2012, have both the standalone & plugin running & activated as far as I can tell, newest versions. The liveDB works fine in maya, as does the ipr view.
However, when I do a batch render, it either renders 1 frame & stops, or says "render complete" when I render a frame that's already finished previously in the viewport...it never goes to the next frame though. I have my render settings setup for a 1-96 frame range, and have my settings in-place as well (as far as I can tell).
Any help would be great, as I'd love to be able to let it render away.
Thanks so much!
John
// Warning: Renderer "OctaneRender" does not provide batch rendered options. //
// Result: Saving temporary file: G:/projects/ipi_contest/jungle_chase/source/maya/00_maya_jungle/scenes/jungle_maya_integrated____ocatne_trees_11__912.mb //
// Result: Rendering with OctaneRender®... //
// Result: Rendering Completed. See mayaRenderLog.txt for information. //
system "\"C:/Program Files (x86)/OctaneRender for Maya/OctaneMaya Plugin v2.58 beta.pdf\"";
here's from when I startup:
requires "OctanePlugin" "v1.0 RC3c beta";
# Octane data types are registered...
# Octane nodes are registered...
# Octane settings store is registered...
# Octane settings instance is created...
# Octane camera is registered...
# Octane tool shelf commands are registered...
# Octane scene translator is registered...
# Starting Octane engine...
# Octane plugin is activated.
# Octane materials LiveDB swatches refresh started...
updateRendererUI;
# Octane UI is registered...
# ...done in 0 min. 4 sec.
JimStar
I need more info to understand what is going on in your system...
Please, enable "Verbose mode" in Octane settings, delete mayaRenderLog.txt before starting batch, and then post here this mayaRenderLog.txt created after batch is finished. Your Octane settings will be needed too, you can post the screenshots of settings tabs here.
johnb4467
Hi, and thanks so much for the prompt reply. I took the screenshots & reset / ran the .txt file before I headed off to work today, so hopefully this will give you the info you need.
Re-running this time, I am noticing that I am getting the same "This account is currently activated on another machine."
However, I've never ran it on another machine...neither the standalone or the plugin. :-/
I'm definitely still not counting out that I may be setting something up incorrectly...thank you again for all your help! :)
Here's the text from the file:
12/11/2012
Starting "D:\Program Files\Autodesk\Maya2012\bin\mayabatch.exe"
mental ray for Maya 2012
mental ray: version 3.9.1.36, Feb 2 2011, revision 138829
[2012/Dec/11|07:25:41] V-Ray: V-Ray for Maya version 2.00.04 cracked by CGP
[2012/Dec/11|07:25:41] V-Ray: V-Ray core version is 2.00.01
Initializing V-Ray for Maya
...done in 0 min. 8 sec.
Error: line 1: Error starting Octane engine: This account is currently activated on another machine. Please deactivate it on the other machine first and wait 30 minutes before re-activating it on this machine, or activate another account/license on this machine.
Error: line 1: Error activate Octane engine: This account is currently activated on another machine. Please deactivate it on the other machine first and wait 30 minutes before re-activating it on this machine, or activate another account/license on this machine.
File read in 9 seconds.
Warning: grass2_particleShape: No cache file found for this object, runup may be needed. Check your workspace particles directory.
Warning: You will need to rewind and play to see your particles. We recommend you then save the file with a startup cache.
Result: G:/projects/ipi_contest/jungle_chase/source/maya/00_maya_jungle/scenes/jungle_maya_integrated____ocatne_trees_11__4764.mb
Error: OctaneRender is not activated!
Error: Scene G:/projects/ipi_contest/jungle_chase/source/maya/00_maya_jungle/scenes/jungle_maya_integrated____ocatne_trees_11__4764.mb failed to render.
// Maya exited with status 210
JimStar
johnb4467
Yes, it is the same problem as the previous user has... It looks like the engine activation issue...
I will ask the engine-team about it, thank you for info.
johnb4467
Perfect, thank you.
In the meantime (if it isn't a simple fix and might take a while to resolve), could you maybe let me know what beta versions of Octane & the Maya Plugin will play well together to where I will be able to batch render, if they happen to know?\
I'll post in the other thread to try and see what versions the other user was using as well.
Thank you again,
John
johnb4467
JimStar, is there by chance a place I can go to download the versions that Rory has working for the batch renderer?
"johnB,
it was Maya Plugin 3.03g Beta,
and Standalone 2.58e
Rory"
Sorry for the hassle; I'm just in need of kicking off some batch renders pretty quick here & want to make sure I'm leaving myself enough time for revisions & review.
Batch Render aside...great stuff so far. :)
JimStar
This release does not exist anymore for downloading...
Can you try to start the batch render such a way: set all needed settings, save scene, close Maya, then right-click on file, pick "Render"... Will it work for you?..
PS. I have said about it to engine developers...
johnb4467
unfortunately, I see the "this account is already registered" dialog fly by when in command prompt, before it closes the command prompt window and spits me back out.
Wonderful suggestion though. :)
Hopefully something will present itself soon!
RealSpace
I am having the same batch render issue as well.
Ian Clark
RealSpace
http://www.realspace3d.com/
Andrew88
yeah i got the issue too.
i hope you guys will fix it soon :)
Return to “Autodesk Maya”
