Demo of OctaneRender for Maya v1.0 beta available!
RayTracey
OTOY is proud to announce the availability of the first Demo of OctaneRender for Maya v1.0 beta.
The world's fastest and most feature rich unbiased render engine that integrates completely into Autodesk® Maya®.
MAYA VERSION REQUIREMENTS
This demo will work with Maya® Versions 2011, 2012, 2013 and 2013.5 / 32-bit & 64-bit on MS Windows operating systems.
Notes regarding features/functionality
OctaneRender™ for Maya® implements almost the full functionality of OctaneRender™ standalone inside Maya®.
Materials from the Live DB are not available.
This demo supports Tesla (GT2xx architecture), Fermi and Kepler GPUs, (GeForce, Quadro and Tesla lines).
Note that the plug-in demo version does not require the standalone version to be installed, however the licensed
version requires both an OctaneRender Standalone license and a OctaneRender for Maya license.
DEMO LIMITATIONS
- The resolution is limited to 1000x600.
- Water marks (Octane logo + stripes).
- No Live DB access.
DOWNLOAD
You can download the OctaneRender for Maya demo from our Downloads page:
http://render.otoy.com/downloads.php
This version requires Nvidia video driver 301.42 or higher.
HOW TO PURCHASE LICENSES
Go to our online shop here: http://render.otoy.com/shop/
If you do not own an OctaneRender™ Standalone Edition License yet:
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as
a reduced price bundle, purchase the bundle priced at 279€
If you already own one or more OctaneRender™ Standalone Edition licenses you want to pair the plugin with:
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
An example video of what can be achieved with the Octane for Maya plug-in:
Freyr
Hi, thanks for demo. But i have some troubles
What`s wrong? I set sun/sky , gpu - ok, in render settings. Applied glossy material to sphere. Where i wrong?
JimStar
Freyr wrote:Hi, thanks for demo. But i have some troubles
Camera. Set Octane camera aperture and/or focus.
Freyr
I tried to play with camera settings, and it make some result. But, anyway, it looks like you know what.
range of numbers - gigantic, i have no idea how to make standart camera settings. And what`s wrong with light?
? Plus - please remove this number range, make it smaller. it is inconvenient for work with it, you want to set to 100, but you are setting 1000. Like this. (
ps - you can set "100" with shift pressed, but only in channel box, not attrib editor)
JimStar
Freyr
You can pick the exact focus by selecting the region in the RenderView during IPR (the current camera focus will be set to the center of this region).
fr3drik
Would it be possible to install the plugin in a central server location?
Meaning, copying the .mll file into MAYA_PLUG_IN_PATH, defining where Maya can find other files such as the octane.dll, octane.dat and octaneRenderer.xml and lastly uninstall the local copy of Octane.
JimStar
fr3drik
I have not understood your goal... Installing it on the server first, then copy somewhere else, and then uninstall from server...:?
What is your task? Why you need it?..
icelaglace
Set the scale to 1.0 in the Octane settings.
http://icelaglace.com
Freyr
Thanks! now i see more results.
Anyway, i hope you`ll make a smaller default number ranges + what about smooth mesh preview?
VERY important thing, because a work with highpoly uv`s - suicide
fr3drik
JimStar wrote:fr3drik
No I meant install locally first, then copy the files onto an arbitrary location (a server) and then uninstall the local installation. Finally run Maya and load the Octane plug-in from the arbitrary location.
We have our studio set up like this for all software that supports it. This helps when maintaining a large number of machines and when switching back and forth between versions.
For example, here's how to install V-Ray like this:
http://www.spot3d.com/vray/help/maya/15 ... om_dir.htm
