Maya Plugin for 2013.5?
Moderator: JimStar
phaskins
I just purchased the Maya plugin and tried to install it for Maya 2013.5 but don't think it installed. Is Maya 2013 Extension supported?
JimStar
phaskins wrote:I just purchased the Maya plugin and tried to install it for Maya 2013.5 but don't think it installed. Is Maya 2013 Extension supported?
Yes.
Can you describe in detail what is the problem?
phaskins
The install seemed to go very fast and said it had finished. I loaded up Maya to look under the plug-in manager but Octane doesn't seem to show up.
JimStar
phaskins wrote:The install seemed to go very fast and said it had finished. I loaded up Maya to look under the plug-in manager but Octane doesn't seem to show up.
Do you not see the "OctanePlugin.mll" there?
Have you checked the checkbox in the installer next to your Maya version?
phaskins
-No OctanePlugin.mll shows up.
-I checked the Maya version for Maya 2013 x86
I did install the 64 bit version of the standalone version of Octane. Do these need to match?
I checked the paths C:\Users\paul\Documents\maya\2013.5 and C:\Program Files (x86)\Autodesk and didn't see anything related to Octane. However, I did see and uninstaller file.
JimStar
Do you see the the file "c:\Program Files (x86)\Autodesk\Maya2013\bin\plug-ins\OctanePlugin.mll"?
phaskins
JimStar wrote:Do you see the the file "c:\Program Files (x86)\Autodesk\Maya2013\bin\plug-ins\OctanePlugin.mll"?
No....
However my path would be C:\Program Files (x86)\Autodesk\Maya2013.5\bin\plug-ins
I'm wondering if the install is getting confused because of the .5 on the end of the Maya2013 folder name.
JimStar
phaskins wrote:No....
Installer gets the path from the registry.
Can you check the MAYA_INSTALL_LOCATION key in the registry at path HKLM\SOFTWARE\Autodesk\Maya\2013\Setup\InstallPath, what value it has? Or perhaps you do not have this path and have the HKLM\SOFTWARE\Autodesk\Maya\2013.5\Setup\InstallPath instead?..
JimStar
Sorry, in you case this path should be like HKLM\SOFTWARE\Wow6432Node\Autodesk\Maya\2013\Setup\InstallPath for x86 Maya installations...
phaskins
Return to “Autodesk Maya”
