OctaneRender™ Standalone v1.0 RC 3 (obsolete)
roeland
We are happy to announce the release of OctaneRender™ v1.0 RC 3. This release fixes a few issues of RC 2 and should be the last
release candidate before final version 1.0.
Changes since v1.0 RC 2
Rendering:
  • Further tuning of the acceleration structure: The increased memory usage and decreased speed should be gone for most scenes.
  • Fixed stability issue when switching between geometry.
Other:
  • Fixed wrong display of free memory after GPU failure.
  • Added menu item to open manual.
  • The name of the directory where Octane stores its settings has changed to .OctaneRender on Linux and OctaneRender on the
    other platforms.
Changes since beta 3.01
  • The file format has been updated. Versions of OctaneRender older than beta 3.02 can't load scenes saved in
    this version
  • The glossy BRDF has been updated. The roughness control has a more linear behavior, and the Fresnel effect
    can be controlled better.
  • CUDA Framework update: There is no longer a separate Kepler build, and users don't have to install a CUDA
    toolkit anymore on Mac OS and Linux.
  • Color accuracy has been improved compared to previous versions.
  • Added near clipping plane to the camera settings.
  • Added caustic blur parameter to the kernel settings to approximate caustics on rough surfaces.
  • Lighting of rough specular materials is rendered more efficiently.
  • Added support for higher texture counts on Kepler GPUs and eliminated error popups when the limit is reached.
  • Quoted command line arguments on Linux are interpreted properly.
Download here:
Windows:
ZIP archives:
- 64-bit32-bit
MacOS X:
- 32-bit and 64-bit
Linux:
- 64-bit
Driver Requirements
This build requires an NVIDIA driver supporting CUDA 4.2.
For Mac OS you need a CUDA driver. We recommend using version 4.2.10 (http://www.nvidia.com/object/mac-driver-archive.html).
The display driver should be automatically updated by Mac OS.
On Linux and Windows you only need a recent enough NVIDIA driver. This release has been tested with driver version 306.97 on Windows and 304.51 on Linux.
Yours,
The OctaneRender™ Team.
gabrielefx
Otoy never sleeps and...
a software never is final...;)
abstrax
gabrielefx wrote:Otoy never sleeps and...
Fixed :)
benjamin9999
In RC2, I experienced a long delay (enough for windows to timeout waiting for messages to be handled) when switching between pmc and other kernels - seems to be fixed in rc3.
pixelrush
does seem to have sped up some. thanks guys. :)
posted my test numbers in the 3.02x experimental thread
is it ok to delete the old preferences folder Refractive Software now?
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
grimm
It's looking good! :) Unfortunately the turntable animation is still broken. At least it doesn't work as it used to. I can select a camera target to rotate around but it still skews the rotation. It is impossible to get the rotation to be limited so it goes around the up axis. Also the camera target position changes as the scene is animated which doesn't seem right to me?
Jason
smicha
Thank you for update.
I'll do some performance tests soon.
PS. Any plans for an image texture displacement/rotation option?
Jaberwocky
Cheers Roeland
Thanks for the new version and for the mac .dmg, unfortunately all the rc os x versions are extremely unstable, it's very difficult to do the benchmarks. here are a couple of crash reports, i hope that you could find a solution :(
ciao beppe
rc3-crash.zip
(27.05 KiB) Downloaded 257 times
ROUBAL
Hello ! Thank you Otoy/Octane Team ! Very Good news about memory usage in RC3 :
I have tested the RC3 release on the exact same scenes as previously, and this time, I have not only no loss, but a gain of 105MB on my big scene instead of a loss of 107MB !
I had the fear that I would have to stay with RC1 to complete my current big scene, but RC3 seems to save me !
Speed is very slightly better, but not much, but the memory usage is more important for me.
Below, screen shots in the RC3-RC2-RC1 (More recent releases first, this time) for template scene "Hallway" and my current scene :
RC3
RC3
RC2
RC2
RC1
RC1
RC3
RC3
RC2
RC2
RC1
RC1
