OctaneRender® for 3ds max® v1.0 beta 3.03[Test]
roeland
@gabrielefx: The 2.58f render is faster because the object covers less pixels on the rendered image. You will see the number of megasamples per second go down if you zoom in.
Roeland
gabrielefx
Karba wrote:2 gabrielefx
Some texture is missed in your archive. Can you send it to us? So we will be sure we have exactly the same scene.
I did the Max archive within the 2.58f. Probably this old release didn't handle properly the texture directories.
I'll do another archive to see if the 3.03 get the the texture files from the assigned directories.
Regarding the speed I'll prepare 2 archives. The zoom factor in my examples it's slight different, I will save the 2 Max scenes with the same camera position and I'll measure the speed again.
boris
has anybody tried instancing with particle flow using shape instance? I birthed 10000 trees but only get several (like 20) in octane live window and also render buffer. particle display is set to ticks but 100% visible. other render engines get all my particles transferred to with the same parameters...
cheers
boris
P6T7 WS SuperComputer / i7 980 @ 3.33GHz / 24 GB / 1500W + 1200W PSUs / 6x GTX 680 4 GB + 1x Tesla M2070 6GB (placeholder :))
gueoct
Any Kepler/GTX6xx experience with the new version?
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
MaTtY631990
Kepler card are about the same performance with the fermi cards. Maybe a little more or less. The real advantages are less power and lot more RAM for a lot less.
acc24ex
the octane window is empty not loading anything?
do I need updated drivers now?
Elvissuperstar007
690 vs 590 ?
Karba
acc24ex wrote:the octane window is empty not loading anything?
What driver version do you have now?
Did you read vesion description?
This version requires video driver 301.42 or higher.
gueoct
Elvissuperstar007 wrote:690 vs 590 ?
that´s what i am curious about, too! / resp. 680 vs. 580...
acc24ex
Whoops - my account was deactivated, my bad, works OK - I guess there should be an error message when deactivated when opening a render window - that would solve that problem in the future
Return to “Autodesk 3Ds Max”
