OctaneRender™ 1.025 beta2.59 test release [obsolete]
Timmaigh
How do i use that damn falloff? There is no manual with the 2.59 version. I wanted to improve some fabric/cloth materials in my latest interior scene using it, but i have no idea, where to put it - bump? opacity? specular?
Some explanation/tutorial would be handy.
EDIT: Ok, with diffuse material i put it into the "Diffuse" channel, now i see the effect. But its black, how do i use it combined with some texture/RGB spectrum color? As i connected it to exactly that same spot, where you usually add "image" texture?
EDIT 2: Oh, seems i got to use it with Mix material? Am i right?
Intel Core i7 980x @ 3,78GHz - Gigabyte X58A UD7 rev 1.0 - 24GB DDR3 RAM - Gainward GTX590 3GB @ 700/1400/3900 Mhz- 2x Intel X25-M G2 80GB SSD - WD Caviar Black 2TB - WD Caviar Green 2TB - Fractal Design Define R2 - Win7 64bit - Octane 2.57
matej
Timmaigh wrote: EDIT 2: Oh, seems i got to use it with Mix material? Am i right?
Yes ;)
(or mix texture)
cgmo.net
Timmaigh
Yes ;)
(or mix texture)
Thanks for response, Matej. Already figured it out, although to know how to use it properly, i will have to do some more testing.
draftart
I bought a 4gb gtx670, on 2.58e failed, and the 2.59 does not see any GPU.
installed every driver from 301.42 to 306.23 all failed (installed only graphic driver and removing every time with sweeper)
WIN7/x64/i7/16RAM/EVGAGTX670 4GB/
hmmm...?
abstrax
draftart wrote:I bought a 4gb gtx670, on 2.58e failed, and the 2.59 does not see any GPU.
hmmm...?
You need install and use either the latest release candidate beta 3.03 (http://render.otoy.com/forum/viewtopic.php?f=33&t=24074) or for the older Octane versions, one of the Kepler builds (like http://render.otoy.com/forum/viewtopic.php?f=33&t=20911), because your GPU is of compute model 3.0 which isn't supported by older Octane versions by default.
I recommend to use the beta 3.03.
Cheers,
Marcus
draftart
hmmm...?
Cheers,
Marcus
many thanks Marcus!
