OctaneRender™ 1.025 beta2.59 test release [obsolete]
RayTracey
The OctaneRender™ Team is proud to announce the test release of OctaneRender™ beta v2.59
New features since beta 2.58
  • Falloff node: a texture which depends on the angle of incidence of the viewing ray.
  • Color correction: applies a levels and gamma correction to the input texture.
  • Russian roulette on colored surfaces has been improved.
  • In the cuda device manager, the checkboxes for GPU’s that are not supported are not shown. You can only enable GPU’s with a supported
    compute model.
  • Smoothing works on a per material input pin basis, rather than per material node. A mix material is smooth if either of its input materials is
    smooth (There is still a bug in the updating of mix materials).
  • If you click on the statistics bar below the rendered image, you get a popup with texture counts and memory usage.
  • Octane contains new shading code, so there is a chance that some materials don’t show up correctly.
  • There are minor changes to the OCS reader.
Download here:
Windows:
ZIP archives:
- 64-bit — 32-bit
MacOS X:
- 64-bit
Linux:
- 64-bit
Driver Requirements: This release was built with CUDA 4.0(http://www.nvidia.com/page/drivers.html).
For Linux and Mac OS you also need to install the CUDA Toolkit 4.0 (http://developer.nvidia.com/cuda-toolkit-40).
For Mac OS you also need the latest CUDA 4.0 driver (http://www.nvidia.com/object/mac-driver-archive.html).
All builds support only Tesla and Fermi cards (compute model 1.0 to 2.1).
Kepler GPUs are not supported at the moment but a fully functional build is being developed.
Yours,
The OctaneRender™ Team.
i can't believe... a new octane version and plus it is @ 64 bit for os x :shock:
thanks a lot, can't wait to test it :D
Elvissuperstar007
Falloff node !!!!!!!!!!!!!! :o
gabrielefx
Elvissuperstar007 wrote:Falloff node !!!!!!!!!!!!!! :o
incredible but true...
trudogolik15rus
"Falloff node" - what is it?
mib2berlin
HI guys, the linux build need a symlink on my opensuse 12.1 to run.
ln -s libGLEW.so.1.6 libGLEW.so.1.7
In /usr/lib64
But no problem so far, testing further.
Cheers, mib.
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
pixelrush
thanks team Otoy! ;)
Octane v1.55
Tugpsx
Thanks. Will play with this one.
marcio_max
trudogolik15rus wrote:"Falloff node" - what is it?
This is a example of falloff shader. Excellent for fabric textures and much more.
| Windows 8 Pro x64 | Octane for 3ds Max/Standalone | i7 860 | 12GB RAM | 1x EVGA GTX 670 4GB / 2x EVGA GTX 670 2GB | Cooler Master HAF 932 |
marcio_max
I'm waiting for Kepler.
But my dream come true when a final version ready for the boards Kepler.
1344 Cuda cores ... I'm dreaming of it working properly. :roll:
