Hi all,
i add a sample that is the result of using the plugin "Grasshopper" for the determination of the matrix, for exact positioning of the instances in Octane Render by scatter node.
A big thanks for the support David Rutten (McNeel) who created the script for Grasshopper.
Ciao
Instance whit rhino
cool, can you share the script?
i can share all you want but not the script because i don't know how to do...
I add the definition of grasshopper that there is the script...
I hope i can help you...
- Generatore_Istanze.zip
- (19.78 KiB) Downloaded 287 times
SORRY, MY ENGLISH IS BAD!
2 Xeon quad core E5440_8gb Ram_Nvidia GeForce 2GTX 780ti 3Gb/Nvidia Quadro K2000_Win10 64bit_Octane 3.02_Rhinoceros3D
Update:
IMPORTANT!!! You need the last version of rhino 4/5 and Grasshopper
- (19.45 KiB) Downloaded 295 times
Hi Daniel,
thank you for sharing.
I will test it soon
I will test it soon
There is a small problem but do not know how to fix it:
I changed the definition of grasshopper to scale objects a random, but the array that creates not take it into account, so unfortunately all instances have the same height.
You can import several object of different heights and with different octane nodes scatter you assign different positioning matrix.
A little intricate but at the moment I see no other solution
bye
bye
