Variable caustics (new): Path Tracing vs Photon Tracing
nuno1980
Hello. I use Octane Render 2022.1 demo despite my Licensed Customer. ;)
We know - the definition of "Variable (or glossy) caustics" is direct+indirect lights reflected and/or refracted on any glossy (not diffuse) ground:
- (almost) 100% focus of lights direct+indirect reflected and/or refracted -> between 0% and 2% roughness of ground
- low to high blur of lights direct+indirect reflected and/or refracted -> between 2%~95% roughness of ground
- bit or little visible of variable caustics on 95%~99% roughness of ground.
-> Can you understand this? :)
Difference between my 2 images rendered about variable caustics at 0.09 (9%) roughness of ground:
- At Path Tracing (PT) kernel - I apologize for noises but I needed very, very long number of samples per pixel
- At new Photon Tracing with denoiser - quick direct+indirect caustics = only 20 seconds on my RTX 4090 but unfortunately, this is not any variable caustics visible at less than 0.3~0.4 (30%~40%) roughness of ground
-> But this new kernel seems to be NORMAL. ;)
--> I'll post to add new image at PT kernel in this night when the new image will be rendered (the camera little moved to right from camera original (see 1st image)). :)
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
nuno1980
nuno1980 wrote:--> I'll post to add new image at PT kernel in this night when the new image will be rendered (the camera little moved to right from camera original (see 1st image)). :)
Sorry for later.
rough 0.09_PT-2_total 2h50min render time - total 2M-spp_7 regions picked of 1M-spp.PNG
See the difference between 2 images (this new and 1st) about caustics "animated" while the camera is moved due to the variable caustics. :)
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
Hello, guys. :D
Watch about "Variable vs almost non-variable caustics at... the real life" but not on computer:
https://youtube.com/shorts/j1Awp-IA3C4
Best regards. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
Hello. :)
New rendered images:
This is easier and better understand about the variable caustics. :)
--> Download - ORBX project <--: Don't forget to change kernel to Photon Tracing (PHT) - check new image above about PHT settings. ;)
Happy Rendering and Best regards. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
Hello. :)
--When the camera is moving--:
-On Photon Tracing, caustics aren't changing due to MISSED "variable" caustics;
-On Path Tracing, caustics are changing despite fixed light source.
Happy Rendering and best regards! :mrgreen: ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
