... and another sss
t_3
because i'm no genius at creating materials and do this mostly by trial & error, i wanted to find out, what difference sss really makes - and so created a side by side example. for me it is hard to tell how subtle (more or less) effects like sss work, because you can tweak any material to a point where it looks good, given a specific setting.
so i created a simple amethyst-like material and put it on the good old dragon. it's easy to see that front dragon looks a lot more consistent then the one in the back, regardless of the thickness (and a lot more natural, if you ask me). of course with the same settings, except scattering.
by the way sss just doesn't work on diffuse materials for me. even the emission parameter has no effect.
btw: if you ever wondered, if it is possible to renderer two (or more) images in parallel - it is. if there is enough vram, cuda seems to equally spread the resources to every running instance of octane ;)
gah5118
where can i download the dragon object?
thanks!
Windows 8.1 | i7 950 | GTX 780ti | 24gb ddr3
t_3
gah5118 wrote:where can i download the dragon object?
thanks!
http://graphics.stanford.edu/data/3Dscanrep/
gah5118
lol thanks, was just about to post that i had found it.
Return to “Works In Progress”
