Octane 2026.6 for Cinema4D - 2.0.4
ChrisHekman
Hi all,
This build contains OctaneRender 2026.6
To see what the future holds, check out our Trello!
https://trello.com/b/1HYU24R0/octanec4d
2026.6 - 2.0.4 Plugin Changes
Changes
  • Rewritten Redshift material conversion: Convert Materials and rendering now translate Redshift node materials through the render path, including textures, ramps, Color Correct, Toon, Hair and Flakes
  • Node editor: Wire Reroute dots (Alt+click a wire to insert one) and Send/Receive Reroute portals that pass a value across a material without a wire
Bug Fixes
  • Vertex Color tags in Polygon Points mode now export the correct per-corner colours, and painting or switching modes updates the Live Viewer; also fixed for rest position, instance colour and vertex map baking
  • Camera tag post processing is no longer switched off in the Live Viewer when a setting changes in the Settings dialog
  • Scatter keep-away is much faster on dense meshes, which could take minutes before
  • Live Viewer no longer draws the timing, export and meshlet cache status text over the render
  • Picture Viewer, Commandline and c4dpy renders no longer hang after a render failure, and the Octane log window opens on the main thread
Downloads:
WINDOWS STUDIO+ 2026.6 - 2.0.4 (R21-R2026)
Installer
Archive
Installer Chinese
Archive Chinese
MacOS Prime 2026.6 - 2.0.4 (R21-R2026)
Archive
WINDOWS DEMO 2026.6 - 2.0.4 (R21-R2026)
Installer
Archive
2026.6 - Nodes
OctaneRender Studio+ 2026.6 Node for Windows (installer)
OctaneRender Studio+ 2026.6 Node for Windows (ZIP archive)
OctaneRender Studio+ 2026.6 Node for Linux
Support
Some important notes about these builds:
The minimum NVIDIA driver version required is R535 (R572 for GeForce RTX50 series).
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
Please note the macOS build will only work correctly on macOS 14.5 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.5.1, R2025.3.3, R2026.1.2). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 528) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRenderforCinema4D.html
Archive Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
Idonee
Hello. For some reason, the latest version of the Studio driver is proving unstable with Octane. I’m referring to the latest version of the Studio driver (6.21.14).
Everything that works perfectly on version 617.42 throws a memory error (CUDA error (700)) on version 6.21.14.
[Error]CUDA error (700) on device 0: an illegal memory access was encountered
[Error] -> failed to launch kernel(kernel37)
[Error]device 0: path tracing kernel failed
[Info]----------------------------------------------------------------------------------------
[Info]<<< Render failure detected!!! >>>
Please check the render statistics to resolve the issue.
[Info] MB:0/0 ST/MOV:0/5 Nodes:37 Tris:2.1m DispTris:0 Hairs:0 Meshes:11
[Info] Textures Grey8/16:14/0 Rgb32/64:17/0
[Info] Render Failure... Please check the Octane log window via the ‘Settings->Other->Show Render Log’ button...
Is it just me? Has anyone else come across something similar?
Tim0042
Idonee wrote: Sun Nov 08, 2026 7:24 pm Hello. For some reason, the latest version of the Studio driver is proving unstable with Octane. I’m referring to the latest version of the Studio driver (6.21.14).
Yeah, something seems to have gone wrong with the latest studio driver. I'm not getting a cuda error so far, but inconsistent specular highlights from frame to frame when rendering via Picture Viewer. The specs also have dimmed compared to before the driver update. Finally, the way the image builds up during rendering has changed, with the highlights not even appearing right away.
