This build contains OctaneRender 2026.6
To see what the future holds, check out our Trello!
https://trello.com/b/1HYU24R0/octanec4d
2026.6 - 2.0.4 Plugin Changes
Changes
- Rewritten Redshift material conversion: Convert Materials and rendering now translate Redshift node materials through the render path, including textures, ramps, Color Correct, Toon, Hair and Flakes
- Node editor: Wire Reroute dots (Alt+click a wire to insert one) and Send/Receive Reroute portals that pass a value across a material without a wire
- Vertex Color tags in Polygon Points mode now export the correct per-corner colours, and painting or switching modes updates the Live Viewer; also fixed for rest position, instance colour and vertex map baking
- Camera tag post processing is no longer switched off in the Live Viewer when a setting changes in the Settings dialog
- Scatter keep-away is much faster on dense meshes, which could take minutes before
- Live Viewer no longer draws the timing, export and meshlet cache status text over the render
- Picture Viewer, Commandline and c4dpy renders no longer hang after a render failure, and the Octane log window opens on the main thread
Downloads:
WINDOWS STUDIO+ 2026.6 - 2.0.4 (R21-R2026)
Installer
Archive
Installer Chinese
Archive Chinese
MacOS Prime 2026.6 - 2.0.4 (R21-R2026)
Archive
WINDOWS DEMO 2026.6 - 2.0.4 (R21-R2026)
Installer
Archive
2026.6 - Nodes
OctaneRender Studio+ 2026.6 Node for Windows (installer)
OctaneRender Studio+ 2026.6 Node for Windows (ZIP archive)
OctaneRender Studio+ 2026.6 Node for Linux
Support
Some important notes about these builds:
The minimum NVIDIA driver version required is R535 (R572 for GeForce RTX50 series).
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models.
IN ANY CRASH CASE PLEASE DO THESE!!!
If you see CUDA errors follow 1,2,3,4.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
2- Check GPU frequency. Overclocking would cause instability issues
3- Check PSU. Insufficient power output would cause instability issues
4- Check the free amount of GPU's VRAM and system's RAM while working. Low VRAM will/may cause CUDA errors. Be aware of some generator objects will have different triangle count in Picture Viewer than Live Viewer. It’s like “editor/render” parameter. Just try to use the same value. Also try to optimize your scene for polygon count, even use smaller images. Try to use Octane texture nodes rather than using C4D texture/shaders.
Alternatively, use V4 and Out-of-core(OOC) function. Increase RAM for OOC and It should not exceed physical RAM amount. Check TDR value and increase if it's necessary.
5- If you see C4D crashes without CUDA errors, then send us bugreport.zip, screen-shots and video capture to show process and crash moment. Also please send us a sample scene in a format of C4D or ORBX to let us investigate and test it. Alternatively, try to delete/hide some objects/materials until crash gone away. If you find what's causing crashes, send us a sample scene to let us for investigating and bring a fix or solution.
Thanks for helping the development by your feedbacks! It’s impossible to quickly catch every case without user feedbacks! It’s the same procedure as other companies do like Maxon/etc...
Please note the macOS build will only work correctly on macOS 14.5 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.5.1, R2025.3.3, R2026.1.2). Otherwise, the plugin will not work and not appear in menus.
-Internet connection for activation, be sure that C4D and Octane will not be blocked by the firewall and any antivirus software.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 528) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
Use embedded help buttons from Octane nodes and windows
or from link: https://docs.otoy.com/cinema4d/OctaneRenderforCinema4D.html
Archive Installation
First, remove all octane related stuff from plugins and the main folder of Cinema4D.
Also, download manual.zip and extract to c4dOctane directory if it's not available in place.
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
