Octane 2026.5 for Cinema4D - 2.0.0
ChrisHekman
Hi all,
This is our first 2.0.0 release! For the last year an a half we have been working on getting the C4D plugin into better shape.
We worked on stability and usability and worked on filling in many of the gaps in existing features.
Additionally we have worked on refactoring and building new sysems to facilitate faster and more stable development of new features.
We will be releasing these new features in the upcomming 2.x.x builds.
For this build we are starting with Realtime Rendering, Texture Manager Refactor, and Gaussian Splat rendering in the C4D viewport.
Furthermore the build has a new look as we have improved the icons of the LV and many of the Octane scene Objects and Tags.
In the upcomming builds we will releasing improvements and features such as:
Multiple Render Settings(RenderTargets), Improved Picture Viewer Export Settings, C4D Nodegraph support
This build contains OctaneRender 2026.5
To see what the future holds, check out our Trello!
https://trello.com/b/1HYU24R0/octanec4d
2026.5 - 2.0.0 Plugin Changes
  • Upgraded to OctaneRender 2026.5
  • Realtime mode in Live Viewer (Windows C4D 2026 only)
    This feature shares the octane render results as a GPU texture with C4D resulting in a smoother and faster LV
    Will be extended with realtime denoising in Octane 2027 giving realtime noisefree results in the LV
    For Multi-GPU setups it is required to have both C4D and Octane use the same GPU for the render results
  • Gaussian splat viewport rendering (C4D 2026 only)
  • Icons update for Live Viewer
  • Icons update for Objects and Tags
  • Texture Manager Refactor
  • Liquid velocity vector support
  • Gaussian splat loading by plugin
  • SPZ format support for Gaussian Splats
  • Added Gaussian log type
  • Voronoi Fracture fragments now each get their own instance ID
  • NRC Online Training and SPP options on Photon, Direct, and Pathtracing kernels
Fixes
  • Fixed anisotropic pins not appearing on material layer nodes
  • Fixed error in the log if a Volume Fog object is created
  • Fixed Color picker live update issue
  • Fixed issue with chinese color space names
  • Removed outdated slider types
  • Fixed MaterialX UI bug in attribute viewer (Happened on latest versions of C4D 2026)
  • Fixed Texture manager mac crash
  • Fixed projection node compatibility issues in older scenes. This fixes issues with upgrading to latest plugin version
  • Fixed first mesh UV set missing its UVW tag name
  • Fixed removed UVW tags leaving their UV set on the Octane mesh
  • Fixed image texture output type when switching between RGB, grayscale and alpha images
  • Fixed crash in deleteSubApiNodes when a node had no object link
  • Fixed warnings/error messages for simulated camera
  • Fixed issue with certain OCIO files
  • Fixed importance sampling issue
Downloads:
WINDOWS STUDIO+ 2026.5 - 2.0.0 (R21-R2026)
Installer
Archive
Installer Chinese
Archive Chinese
MacOS Prime 2026.5 - 2.0.0 (R21-R2026)
Archive
WINDOWS DEMO 2026.5 - 2.0.0 (R21-R2026)
Installer
Archive
2026.5 - Nodes
OctaneRender Studio+ 2026.5 Node for Windows (installer)
OctaneRender Studio+ 2026.5 Node for Windows (ZIP archive)
OctaneRender Studio+ 2026.5 Node for Linux
Support
Some important notes about these builds:
The minimum NVIDIA driver version required is R535 (R572 for GeForce RTX50 series).
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
Please note the macOS build will only work correctly on macOS 14.5 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.5.1, R2025.3.3, R2026.1.2). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 528) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRenderforCinema4D.html
Archive Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
twik25
I might be missing something, but I can not get the lighting (real-time) view to work. I have tried installing standalone to match. I have 2 A5000's, but one 1 A5000 card active in both c4D and standalone. I'm using Windows, and C4D 2026.4. I hit the lighting button and it is black. I have tried with a completly new scene with nothing in it, same results. I can see the progress bar moving, it is just not showing anything. Nvidia driver version 580.
ChrisHekman
twik25 wrote: Mon Oct 05, 2026 12:40 pm I might be missing something, but I can not get the lighting (real-time) view to work. I have tried installing standalone to match. I have 2 A5000's, but one 1 A5000 card active in both c4D and standalone. I'm using Windows, and C4D 2026.4. I hit the lighting button and it is black. I have tried with a completly new scene with nothing in it, same results. I can see the progress bar moving, it is just not showing anything. Nvidia driver version 580.
There are issues with multi-gpu atm. Usually it gets fixed when switching the active Octane gpu while the plugin is running. We are investigating a fix for the multi-gpu issue.
