Attribute node returns flat white on xpTrail per-vertex color regardless of Name field
swilkerson101
Hello I'm trying to get my XPtrails to have the same texture and color as my particle emitter, but the attribute node returns flat white on xpTrail per-vertex color regardless of Name field, while W coordinate/Gradient map on the same geometry renders correctly. Is there a bug or any reason why this function still does not work. I looked in the forums and the last post about this subject was over a year ago. Has there been a fix to this problem, or is this something I need to talk to INSYDIUM about? I have attached my project file below.
Cinema 4D 2025.3.3
Octane version: 2026.3 Build 1.9.3
Windows
GTX 5090
96 Gig Ram
AMD Ryzen 9 9950X3D
XP Trail Error.zip
(233.97 KiB) Downloaded 21 times
I suspect that the issue is caused by Chinese name attribute:
Trail color works ok here with english name attribute:
ciao,
Beppe
