Passes and AOVs
HHbomb
HI,
I was using denoised lighning pass in AOV in max slate editor, but it seems that it dooesn't update properly. When I use the Octane node editor, all seems to be fine....
paride4331
HHbomb,
It looks like it’s working on my end. Could you show me a node structure video you created?
Regards
Paride
HHbomb
Hi Paride ! It seems that it is a problem with cloning nodes in Slate Material Editor...
If I create nodes it seems to work, but when I'm lazy and I clone a group of nodes and change just for exemple the light number, it don't work.
paride4331
Hi HHbomb,
I tried cloning the AOV nodes, but I can't seem to reproduce the issue. I'm probably doing something different than you. Any chance you could record a quick video showing your workflow? That'd help me figure out what's going on.
Regards
Paride
HHbomb
pfff can't reproduce on a simple file... :roll:
Return to “Autodesk 3Ds Max”
