Octane 2026.2 for Unreal Engine - 0.89
Moderator: ChrisHekman
ChrisHekman
Hi all
The settings for Meshlets and Virtual texturing are in the plugin settings. (Easy access in the dropdown menu: Octane -> Plugin Settings)
When set to manual (which is default), you can rightclick StaticMeshes and Textures assets in the content browser and
turn them on by going to the Octane section. (This is similar to how nanite is turned on for meshes)
Note that you need to reload the virtual assets in octane in order for settings changes to take affect.
Note: There are currently stability issues with both Virtual Texturing and Meshlets. When encountering render failures it is adviced to turn virtual settings off
Octane for Unreal Engine
Changes:
  • Fixed various minor material conversion issues
  • MRQ ORBX export now activates Octane on tier 2
  • Refactored how specular is converted from Unreal to Octane
  • Fixed various minor decal material bugs when no nodes are connected to material inputs
  • Blackbody node now converts correctly
  • Removed unnessesary warning
  • Fixed rare crash that happened on certain materials
  • Fixed parameter collection bug
WIN
UE 5.7
Studio+ Installer: https://render.otoy.com/customerdownloads/plugins/a1/ba/ec/2c/OctaneStudio0_89_UE5_7.exe
Free Version Installer: https://render.otoy.com/plugindownloads/61/cc/b6/aa/OctanePrime0_89_UE5_7.exe
UE 5.6
Studio+ Installer: https://render.otoy.com/customerdownloads/plugins/f7/00/26/fb/OctaneStudio0_89_UE5_6.exe
Free Version Installer: https://render.otoy.com/plugindownloads/7a/39/ff/e5/OctanePrime0_89_UE5_6.exe
Jani
Hi Chris,
any change you could do an Unreal 5.5 build of this? Would it work?
I would be very grateful.
Thank you!
Jani
i9 9920X, 64GB, RTX 2080Ti
Ryzen 1800x, 64GB, 2x RTX 3090
solomon
The MetaHuman skin textures are not rendering properly...
Solomon W. Jagwe
ChrisHekman
Jani wrote: Wed Apr 01, 2026 7:27 am Hi Chris,
Thank you!
Jani
Here you go. I have added 5.5 to the latest build. I do advice you to upgrade as I only support the latest two versions normally.
viewtopic.php?t=85641
ChrisHekman
solomon wrote: Tue Apr 07, 2026 4:29 pm The MetaHuman skin textures are not rendering properly...
Thanks, ill take a look what happened.
