multiple uvs
Houdini Integrated Plugin
marcikola
hi!
i want to use multiple uvs for a dual rest setup, so i have one uv called uv1 and another called uv2, which i want to blend in the shader.
how can i access these different uvs in the shader? it only grabs the standard uv, but i can't get these with different names.
thank you in advance!
dom_otoy
You use the mesh uv projection. It has a selector for which uv to use for the connected texture.
Note that in houdini the naming is @uv @uv2 and @uv3 (a little confusing)
Happy Rendering!
Dom - Octane Houdini QA Engineer
:!: Btw did you know Octane has a discord? https://discord.gg/F4WENTG :!:
It's a great place to get very fast feedback or support from me and other Octane Houdini users.
I'd highly recommend it!
marcikola
Ah, that was the problem. Thank you, works well!
Return to “Houdini”
