Octane 2026.1 for Cinema4D - v1.8
ChrisHekman
Hi all,
Here is our Octane 2026.1 for Cinema4D release
For this build we have improved and expanded Octane 2026 support across the plugin,
and fixed a couple of other issues and added User Data Tag and Mograph Data support!
While Octane 2026 now out of beta, and we implemented the new features in the plugin, do keep in mind that we are still working on
improving the new features, and that they may be subject to change while we hammer out the kinks.
We will be releasing a 1.8 buid for Octane 2025.5 next week.
Have a good day, and for those in the US, I hope you have a good thanksgiving,
- Chris
To see what the future holds, check out our Trello!
https://trello.com/b/1HYU24R0/octanec4d
2026.1 - v1.8 plugin revisions
  • Major Changes
    • Updated to Octane 2026.1
    • Support for C4D’s User Data Tag (via AttributeTex node)
    • Mograph Data support (via AttributeTex node)
    • Added OpenPBR Material
  • Material Changes
    • IOR is now a texture input instead of a float
    • Anisotropic is now a texture input instead of a float
    • CMYK added Halftone texture node
    • Added MaterialX nodes: Fractal2D, LatLongImage, HexTiledImage, and HexTiledNormalMap
    • Added displacement node quality pin
    • Added Sheen BRDF
    • Added Oren–Nayar (energy preserving) to BRDFs
    • Improved UI layout for various nodes and objects
  • Scene & Geometry
    • Added TraceSets to Octane Lights and Environments
    • Improved Meshlets support
    • Updated Vectron Object variables for 2026
    • Added new pins to Gaussian Plat Object: Clip Bounds Transform, Clipping mode, Priority,
  • Textures
    • Added Virtual Texture option to texture nodes
    • Known issue: Virtual textures make material previews render black
  • Settings
    • Added UI for new Upsampling settings on the imager
    • Added Kernel compatibility modes
  • AOV
    • Added new nodes: Cryptomatte Mask, Expand/Contract, Reblend, Unblend
    • Added Environment (unoccluded) render AOV
    • Added PostFX media AOV
    • Added “Lock render” option to AOVs
    • Added “Effects” to multiple AOV nodes
    • Renamed Checkpoint → Snapshot
    • Various minor text/name updates
    • Added "Info/Gaussian Splat Info AOV"
    • Added "Beauty – Other/Gaussian Splat AOV"
    • Adding an Alpha AOV in the Render AOV Tab now works correctly
  • Fixes
    • Fixed infinite VP rendering with Use denoised beauty pass + info channel
    • Fixed crash related to image tiles
    • TraceSets now work properly in the Picture Viewer
  • Known Issues
    • Virtual textures make texture/material previews render black (but work in Live Viewer)
    • Duplicate "Open In Editor" button in PBR material basic tab
    • Mac has an incorrect renderfailure detection error when there is no render failure:
      "<<< Render failure detected!!! >>> Please check render statistics to solve the problem."
    • Gaussians splats have a wireframe material - this might be removed at a later date
Downloads:
WINDOWS STUDIO+ 2026.1 - v1.8 (R21-R2026)
Installer: https://render.otoy.com/customerdownloads/80/37/75/41/OctaneRender_Studio%2B_2026.1_for_Cinema4D_v1.8.exe
Archive: https://render.otoy.com/customerdownloads/ed/e8/d6/9d/OctaneRender_Studio%2B_2026.1_for_Cinema4D_v1.8_Bundle.zip
MacOS Prime 2026.1 - v1.8 (R21-R2026)
Archive: https://render.otoy.com/plugindownloads/81/5c/c0/a2/OctaneRender_Prime_2026.1_for_Cinema4D_v1.8_macos.zip
WINDOWS DEMO 2026.1 - v1.8 (R21-R2026)
Installer: https://render.otoy.com/downloads/73/66/10/1d/OctaneRender_Demo_2026.1_for_Cinema4D_v1.8.exe
Archive: https://render.otoy.com/downloads/1a/fb/4f/ef/OctaneRender_Demo_2026.1_for_Cinema4D_v1.8_Bundle.zip
2026.1 - Nodes
Installer: OctaneRender Studio+ 2026.1 Node for Windows (installer)
Archive: OctaneRender Studio+ 2026.1 Node for Windows (ZIP archive)
Linux: OctaneRender Studio+ 2026.1 Node for Linux
Support
Some important notes about these builds:
The minimum NVIDIA driver version that is required by this version is 528. You can launch Octane with an older driver version, but it will fail to render and it will produce an error message in the log.
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
Please note the macOS build will only work correctly on macOS 14.5 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.4.0, R2025.0.2). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 528) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRenderforCinema4D.html
Archive Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
UON.Visuals
AWESOME THANK YOU!!!!!!!!!!!!! I've been checking the forum often for this release, I can't wait to play with it!
UON.Visuals
Aaaand I already broke it :D
DinoMuhic
UON.Visuals wrote: Thu Nov 27, 2025 9:51 pm Aaaand I already broke it :D
That's for releasing stuff on Thanksgiving :D
Fixing...
ChrisHekman
Both logging errors should not impede you from using the plugin. We have a fix for them that we will release shortly.
dinf
That is great and exciting, thanks to your continous great work! And I love to be able to look at the trello plan!
However, this minor thing:
ChrisHekman wrote: Thu Nov 27, 2025 8:20 pm...
this double version, is confusing me a bit.
I presume 2025-v1.8 will NOT be the same then 2026.1-v1.8, right?
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
ChrisHekman
dinf wrote: Fri Nov 28, 2025 12:17 pm That is great and exciting, thanks to your continous great work! And I love to be able to look at the trello plan!
It is the same version of the plugin - but without 2026 features.
We gave the plugin its own consisten version because it was getting too confusing to keep track which versions of the plugin were the the same as others.
For example under the old versioning system 2025 would have been R3, and 2026 would have been R2 or not have an R number at all - eventhough they were the same plugin version.
twik25
Can you confirm that the new NRC only works with a single GPU? With multiple GPUs (a5000's) I have a visible seam running down the middle in both live preview and render.
**Update - it looks like it might be an issue with static noise on? If I disable static noise, , NRC seems to be working at lower samples.
dinf
ChrisHekman wrote: Fri Nov 28, 2025 1:50 pm
Ah, okay - good to know! Thx for the explanation!
astrofalcon
Fantastic can't wait to try out this release once I'm back in town! Is the new displacement fully functional in this release?
