Octane 2026.1 for Cinema4D - v1.8
ChrisHekman
Hi all,
Here is our Octane 2026.1 for Cinema4D release
For this build we have improved and expanded Octane 2026 support across the plugin,
and fixed a couple of other issues and added User Data Tag and Mograph Data support!
While Octane 2026 now out of beta, and we implemented the new features in the plugin, do keep in mind that we are still working on
improving the new features, and that they may be subject to change while we hammer out the kinks.
We will be releasing a 1.8 buid for Octane 2025.5 next week.
Have a good day, and for those in the US, I hope you have a good thanksgiving,
- Chris
To see what the future holds, check out our Trello!
https://trello.com/b/1HYU24R0/octanec4d
2026.1 - v1.8 plugin revisions
  • Major Changes
    • Updated to Octane 2026.1
    • Support for C4D’s User Data Tag (via AttributeTex node)
    • Mograph Data support (via AttributeTex node)
    • Added OpenPBR Material
  • Material Changes
    • IOR is now a texture input instead of a float
    • Anisotropic is now a texture input instead of a float
    • CMYK added Halftone texture node
    • Added MaterialX nodes: Fractal2D, LatLongImage, HexTiledImage, and HexTiledNormalMap
    • Added displacement node quality pin
    • Added Sheen BRDF
    • Added Oren–Nayar (energy preserving) to BRDFs
    • Improved UI layout for various nodes and objects
  • Scene & Geometry
    • Added TraceSets to Octane Lights and Environments
    • Improved Meshlets support
    • Updated Vectron Object variables for 2026
    • Added new pins to Gaussian Plat Object: Clip Bounds Transform, Clipping mode, Priority,
  • Textures
    • Added Virtual Texture option to texture nodes
    • Known issue: Virtual textures make material previews render black
  • Settings
    • Added UI for new Upsampling settings on the imager
    • Added Kernel compatibility modes
  • AOV
    • Added new nodes: Cryptomatte Mask, Expand/Contract, Reblend, Unblend
    • Added Environment (unoccluded) render AOV
    • Added PostFX media AOV
    • Added “Lock render” option to AOVs
    • Added “Effects” to multiple AOV nodes
    • Renamed Checkpoint → Snapshot
    • Various minor text/name updates
    • Added "Info/Gaussian Splat Info AOV"
    • Added "Beauty – Other/Gaussian Splat AOV"
    • Adding an Alpha AOV in the Render AOV Tab now works correctly
  • Fixes
    • Fixed infinite VP rendering with Use denoised beauty pass + info channel
    • Fixed crash related to image tiles
    • TraceSets now work properly in the Picture Viewer
  • Known Issues
    • Virtual textures make texture/material previews render black (but work in Live Viewer)
    • Duplicate "Open In Editor" button in PBR material basic tab
    • Mac has an incorrect renderfailure detection error when there is no render failure:
      "<<< Render failure detected!!! >>> Please check render statistics to solve the problem."
    • Gaussians splats have a wireframe material - this might be removed at a later date
Downloads:
WINDOWS STUDIO+ 2026.1 - v1.8 (R21-R2026)
Installer: https://render.otoy.com/customerdownloads/80/37/75/41/OctaneRender_Studio%2B_2026.1_for_Cinema4D_v1.8.exe
Archive: https://render.otoy.com/customerdownloads/ed/e8/d6/9d/OctaneRender_Studio%2B_2026.1_for_Cinema4D_v1.8_Bundle.zip
MacOS Prime 2026.1 - v1.8 (R21-R2026)
Archive: https://render.otoy.com/plugindownloads/81/5c/c0/a2/OctaneRender_Prime_2026.1_for_Cinema4D_v1.8_macos.zip
WINDOWS DEMO 2026.1 - v1.8 (R21-R2026)
Installer: https://render.otoy.com/downloads/73/66/10/1d/OctaneRender_Demo_2026.1_for_Cinema4D_v1.8.exe
Archive: https://render.otoy.com/downloads/1a/fb/4f/ef/OctaneRender_Demo_2026.1_for_Cinema4D_v1.8_Bundle.zip
2026.1 - Nodes
Installer: OctaneRender Studio+ 2026.1 Node for Windows (installer)
Archive: OctaneRender Studio+ 2026.1 Node for Windows (ZIP archive)
Linux: OctaneRender Studio+ 2026.1 Node for Linux
Support
Some important notes about these builds:
The minimum NVIDIA driver version that is required by this version is 528. You can launch Octane with an older driver version, but it will fail to render and it will produce an error message in the log.
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models.
IN ANY CRASH CASE PLEASE DO THESE!!!
If you see CUDA errors follow 1,2,3,4.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
2- Check GPU frequency. Overclocking would cause instability issues
3- Check PSU. Insufficient power output would cause instability issues
4- Check the free amount of GPU's VRAM and system's RAM while working. Low VRAM will/may cause CUDA errors. Be aware of some generator objects will have different triangle count in Picture Viewer than Live Viewer. It’s like “editor/render” parameter. Just try to use the same value. Also try to optimize your scene for polygon count, even use smaller images. Try to use Octane texture nodes rather than using C4D texture/shaders.
Alternatively, use V4 and Out-of-core(OOC) function. Increase RAM for OOC and It should not exceed physical RAM amount. Check TDR value and increase if it's necessary.
5- If you see C4D crashes without CUDA errors, then send us bugreport.zip, screen-shots and video capture to show process and crash moment. Also please send us a sample scene in a format of C4D or ORBX to let us investigate and test it. Alternatively, try to delete/hide some objects/materials until crash gone away. If you find what's causing crashes, send us a sample scene to let us for investigating and bring a fix or solution.
Thanks for helping the development by your feedbacks! It’s impossible to quickly catch every case without user feedbacks! It’s the same procedure as other companies do like Maxon/etc...
Please note the macOS build will only work correctly on macOS 14.5 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.4.0, R2025.0.2). Otherwise, the plugin will not work and not appear in menus.
-Internet connection for activation, be sure that C4D and Octane will not be blocked by the firewall and any antivirus software.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 528) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
Use embedded help buttons from Octane nodes and windows
or from link: https://docs.otoy.com/cinema4d/OctaneRenderforCinema4D.html
Archive Installation
First, remove all octane related stuff from plugins and the main folder of Cinema4D.
Also, download manual.zip and extract to c4dOctane directory if it's not available in place.
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
UON.Visuals
AWESOME THANK YOU!!!!!!!!!!!!! I've been checking the forum often for this release, I can't wait to play with it!
UON.Visuals
Aaaand I already broke it :D
DinoMuhic
UON.Visuals wrote: Thu Nov 27, 2025 9:51 pm Aaaand I already broke it :D
That's for releasing stuff on Thanksgiving :D
Fixing...
Return to “Releases”
