Bug Report & feature requests, long-time user.
jonnylynn
Hey Folks,
I've been using Octane for 4-5 years now with max, it's made some of the work I do very effective and I especially love rendering quick sequences with the render management tool and RNDR cloud rendering. It's been great. This is my first post on here about Max with some reports and feature requests.
I recently updated to max 2026 from 2024 and installed the latest build of octane.
Firstly, bugs I've felt/seen straight away:
1- Max's "physical" material now doesn't render correctly, no matter what lighting situation there is like a pink sheen off objects:
2- The Live database button now doesn't work at all. I really liked this Octane live DB button as it was a great quick solution for decent looking materials on the fly in some instances, I'm sorely missing it! Does not work from the render settings menu or from the dropdown.
These are pretty big in my opinion, as I was working with physical material and the live db since I began with octane in max. It is frustrating that when opening old scenes or FBX scenes with physical material I now deal with this rendering issue.
Some requests also:
1. The main reason I actually use the physical material over the universal material in some instances is due to the fact I can see the bitmap in the viewport, with any octane material you can't see the albedo in the viewport, is this something that could be implemented? It's very useful to be able to see this when applying and scaling quick UVW projections, without having to open live octane live view port. This is a minor request though.
2. Secondly, would it be possible to get max's new default material compatible with octane? It's the OpenPBR material.(with bitmap viewable in the viewport as with physical).
Many thanks!
I'm on the latest version of max and latest stable release of octane, using an RTX3090 gpu.
Jonny.
paride4331
Hi jonnylynn ,
The liveDB issue has already been resolved in the version that will be released soon. As for the physical material issue, I was able to reproduce it on my end and I’m sending my report to the developers, along with your suggestions for improving the plugin.
Regards
Paride
jonnylynn
Hey Paride,
I really appreciate the response. I look forward to the update!
Jonny.
paride4331
Hi jonnylynn,
In Octane v2026, you’ll get native OpenBPR support, along with the already available MaterialX and the standard surface material shader (Arnold).
Regards
Paride
jonnylynn
Hey,
Just wanted to come back and show my appreciation for this update.
Open PBR working AND the diffuse texture is showing in the viewport, 2 birds with one stone guys... time to move on from maxs' physical material then. Amazing! I will continue to sing octane for max all the praises. LIVE DB working again too.
Thanks for all the hard work!
Jonny.
Return to “Autodesk 3Ds Max”
