OctaneRender 2025.4 for Houdini production (2025.4.0.0)
bruce.chai
This is a production release of the OctaneRender™ 2025.4.0.0 for Houdini™ plugin compiled with the Octane 2025.4 core. This 2025.4.0.0 release is available for the latest Houdini production builds on Windows x64, Linux, and macOS arm64.
Houdini production builds supported by this release: 20.0.896, 20.5.613, 20.5.654, 20.5.684, 21.0.440 and 21.0.512.
If you are not sure if your Houdini version is compatible with the plugin - just run it and you will see an error message in case of incompatibility.
Linux Note
On Linux only default Houdini builds are supported.
This means that for Houdini 20.0, 20.5 and 21.0 gcc11.2 builds are supported.
New features
To learn more about the new features and improvements of OctaneRender 2025.4.0, please check out the 2025.4 release post
Known bugs
On Linux, MPlay IPR may not be working. If you are having problems with it, please switch to QT5 IPR and disable "Render to MPlay" in ROP nodes.
Downloads
Release 2025.4.0.0 Studio+ license
Windows Houdini 20.0.896
Windows Houdini 20.5.613
Windows Houdini 20.5.654
Windows Houdini 20.5.684
Windows Houdini 21.0.440
Windows Houdini 21.0.512
Linux Houdini 20.0.896 (gcc11.2)
Linux Houdini 20.5.613 (gcc11.2)
Linux Houdini 20.5.654 (gcc11.2)
Linux Houdini 20.5.684 (gcc11.2)
Linux Houdini 21.0.440 (gcc11.2)
Linux Houdini 21.0.512 (gcc11.2)
Release 2025.4.0.0 macOS Prime license
MacOS Houdini 20.0.896
MacOS Houdini 20.5.613
MacOS Houdini 20.5.654
MacOS Houdini 20.5.684
MacOS Houdini 21.0.440
MacOS Houdini 21.0.512
Release 2025.4.0.0 Demo version
Release Notes
RELEASE 2025.4.0.0
PLUGIN FEATURES AND FIXES:
  • Fixed errors when copy/paste octane light or quick material
  • Made Composite Texture layer count a slider
  • Fixed IPR an crash caused by Disabling/enabling Scene Update
  • Fixed instance attribute's values cannot be over 1
  • Fixed the instance Texture count can only be less than 65536
  • Fixed a typo in an error message
OctaneRender for Houdini tutorial
Still updating
Note
From 2025.1.Beta_1.0, Octane plugin for Houdini uses Houdini package file. Each build ships a script (createPackageFileForOctane.bat for Windows, createPackageFileForOctane.sh for Linux and Mac) to help create the Octane.json file as below under C:\Users\<username>\Documents\houdiniXX.Y\packages on windows, ~/Library/Preferences/houdini/XX.Y/packages on Mac, or ~/houdiniXX.Y/packages on Linux.
    "enable": true,
    "env": [
            "OCTANE_AUTOSPAREPARAMS": {
                "value": 1
            "OCTVERSION": "<path_to_plugin_directory>"
            "HOUDINI_PATH": {
                "value": "$OCTVERSION"
            "HOUDINI_MENU_PATH": {
                "value": "$OCTVERSION/config/Menus"
            "HOUDINI_SCRIPT_PATH": {
                "value": "$OCTVERSION/scripts"
            "PATH": {
                "value": "$OCTVERSION/bin"
            "PXR_PLUGINPATH_NAME": {
                "value": "$OCTVERSION/dso/usd_plugins"
Important Note
2024.1.0.2 fixed the problem that the layered material nodes cannot be loaded properly, however this fix affects all layered material nodes and OSL material nodes in existing saved .hip files. When loading a .hip file for the first time using this build, it's necessary to adjust the connections of these nodes. Once the file is saved with the updated connections, the issue will be resolved.
Common Issues and Solutions
- If the plugin doesn't work at all, set HOUDINI_DSO_ERROR = 2 in houdini.env and check for messages in the terminal.
- If you're missing libglut.so.3, install the freeglut package. On some Linux distributions, you may also need to manually create a libglut.so.3 symlink pointing to the current version in /lib/x86_64-linux-gnu.
- If you are having any issues with the Deadline - please submit a support ticket to the AWS.
Happy rendering,
Your OTOY Team
