how to render vertex color in Octane
ajmstudio
Hi, I ahve created a particule system in Tyflow with vertex color.
It work perfectly with Scanline Renderer in 3dsmax but I can't figure out how to render vertex color with Octane render.
Do you have any clue ?
Jm
paride4331
Hi ajmstudio,
https://docs.otoy.com/3dsmax/ColorVertexAttribute.html
The attached screenshot refers to the Octane geometry properties panel.
Regards
Paride
ajmstudio
Hi, thank you for your answer. Could you be a little bit more specific ? where am I supposed to put this Octane geometry properties modifier ? on the Tyflow system or on the original object? And what are the seetings ? I am sorry to ask all these questions but the documentation is not so clear for me. Thanks a lot for your precious help.
paride4331
Hi ajmstudio,
I’m not exactly sure what you need to do, but in general vertex colors work like this, as shown in the attached file.
Regards
Paride
01.zip
(222.69 KiB) Downloaded 41 times
Return to “Autodesk 3Ds Max”
