Nodal hair viewport refresh
BorisGoreta
When working with nodal hair parameters Octane viewport does not reflect the changes made to the hair. I need to set the viewport to solid shading and then back to Rendered view to see the changes. Is that normal ?
BorisGoreta
Apparenlty you need to be in Sculpt mode and then all the changes you doto hair immediately update in the Octane viewport. This doesn't work if you are in object mode.
linograndiotoy
We'll check this, thanks!
linograndiotoy
It looks fine in the addon version.
Could you please describe the steps to reproduce the problem?
Thanks!
BorisGoreta
Yes it works with the 4.5.4 + 30.9.1 Addon.
Can I have motion blur on geo nodes hair on deformable mesh ?
If not how can I set up multi pass MB ? That's where Octane renders x non MB frames each shifted in time a little and then outputs a final average image, effectively making a motion blurred image.
linograndiotoy
Motion blur should work for hair. I'll check this.
Return to “Blender”
