Octane 2026 Alpha 3 for Cinema4D - v1.7.1
ChrisHekman
Hi all,
The main change for this build is C4D R2026 support.
For the rest we focussed on fixes and UI cleanup.
To see what the future holds, check out our Trello!
https://trello.com/b/1HYU24R0/octanec4d
2026 Alpha 3 - v1.7.1 plugin revisions
Changes:
  • Added support for Cinema4D R2026
  • Fixed PSD alpha export issues with picture viewer
  • Fixed Redshift material conversion crash
  • "Use Denoised Beauty pass" OctaneRender setting works again
  • Added 2025 compatibility modes
  • Added LOD Selection bias setting to kernels
  • Thin Wall option now works on sub-materials
  • Transmission type is removed from sub-materials that dont support it
  • Add denoiser quality pin
  • New nodes now correctly update live viewer again
  • Added pin for planetary albedo texture
  • Added option to change wire color in node editor
  • Removed red outline on nodes in nodeeditor
  • Node editor text color setting now works
  • Unused render settings are now hidden in OctaneRender settings
  • Removed preview box as it is only for materials
  • Fixed overlapping text on certain nodes in the node editor
  • Removed "." at the end of various number input boxes across the plugin
  • Updated Copyright
Downloads:
WINDOWS STUDIO+ 2025 Alpha 3-v1.7.1 (R21-R2026)
Installer: https://render.otoy.com/customerdownloads/plugins/93/48/32/ee/OctaneRender_Studio%2B_2026.1_Alpha_3_for_Cinema4D_v1.7.1-beta1.exe
Archive: https://render.otoy.com/customerdownloads/plugins/d6/27/39/ec/OctaneRender_Studio%2B_2026.1_Alpha_3_for_Cinema4D_v1.7.1-beta1_Bundle.zip
Support
Some important notes about these builds:
The minimum NVIDIA driver version that is required by this version is 528. You can launch Octane with an older driver version, but it will fail to render and it will produce an error message in the log.
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
Please note the macOS build will only work correctly on macOS 14.5 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.4.0, R2025.0.2). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 528) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRenderforCinema4D.html
Archive Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
Amaterasu
Guys, thank you for your work. I'm really looking forward to the stable version 2026, but right now I've found a bug with displacement: when I enable displacement in the material settings, my texture breaks, and when I open the node editor, my cinema scene crashes. This happens because displacement is enabled in the material settings.
Video demonastration of the problem
2025-09-22 01-59-26.mp4
(23.48 MiB) Downloaded 157 times
Amaterasu wrote: Sun Sep 21, 2025 11:09 pm Guys, thank you for your work. I'm really looking forward to the stable version 2026, but right now I've found a bug with displacement: when I enable displacement in the material settings, my texture breaks, and when I open the node editor, my cinema scene crashes. This happens because displacement is enabled in the material settings.
Video demonastration of the problem 2025-09-22 01-59-26.mp4
Yes, sorry, it is a known issue of 2026.1-Alpha3 SDK.
We need to wait for next Alpha update to have a fix.
ciao,
Beppe
Hurricane046
Can confirm the Displacement Bug.
Whenever I launch this scene in C4D 2026.0 + Octane 2026 Alpha 3 - v1.7.1 which features ground material with displacement it crashes in like 2 seconds. Or it starts, shows completely messed up texture and then crashes. Same thing happens with our other scenes.
DinoMuhic
Hurricane046 wrote: Mon Sep 22, 2025 8:18 am Can confirm the Displacement Bug.
Texture Displacements are broken in this Alpha, there is nothing we can do about it on the plugin side, we have to wait for a new Octane Standalone version to get released first.
Once that is the case, we will upgrade ASAP. Sorry for the inconveniences, it's an Alpha build so issues are expected and it should not be used in production yet.
cjadams
/Is there a MacOS cinema 4d 2026 build yet?
I see a 2025 build that said it supported 2026... so which is it?
cjadams wrote: Fri Sep 26, 2025 4:42 pm /Is there a MacOS cinema 4d 2026 build yet?
Yes, we included the support to new Maxon C4D 2026 in both OctaneRender 2025.3-v1.7.1 and 2026.1-Alpha3-v1.7.1, but on macOS you can only install OctaneRender 2025.3-v1.7.1 version for now.
There is not an OctaneRender Standalone/SDK 2026.1-Alpha3 for macOS, we need to wait for next 2026.1-Alpha4 version to have a macOS plugin version.
Unfortunately, it is a bit confusing now that almost all applications are taking the year in their name version :(
ciao,
Beppe
ChrisHekman
C4D and Octane both use Years as version numbers, making it easy to mix them up. Even our internal QA got confused by this.
To try and alleviate this version confusion between Octane and C4D, we now always include Name + Version when mentioning a version number.
For example the title of this post is "Octane 2026 Alpha 3 for Cinema4d" instead of the old title format: "Cinema4D version 2026 Alpha 3". The version here referring to the octane version.
And in the patchnote we write: Added support for Cinema4D R2026. The version here referring to C4D
cjadams
Octane has always been full of great devs… thanks for all the hard work and clarification.
cjadams
This update released pretty fast but….. - May i ask whats holding up the Mac version of 2025 & 2026 betas?
ChrisHekman wrote: Mon Sep 29, 2025 9:14 am
