liveDB/LocalDB
dinosgr
This is the 5th time I try to work with Octane for modo.
all times I deleted everything as I could not load a material from live or Local DB i have already in my computer with materials I have created on blender or Daz3d,
Also i cant even save a material in modo, how is this stable ? can't do even the simplest things.
Can someone chime and enlight me , cause i feel dump, off course the paths are fine as I can see local and Live Database with no problem. Import do nothing at all.
Thanks In advance
Konstantinos
Hi Konstantinos
When reporting an issue - can you please provide the information requested at viewtopic.php?t=84818 in the "Support Issues" section.
dinosgr
Hope this is enaugh
- Modo version 17.1.v1
- OctaneRender Prime for Modo version 2025.3.0.206
- Operating System Windows 11
- Amount of RAM 32 GB
- Graphics Card(s) - model RTX 970 Super
- Nvidia driver version 581.29 Studio driver
Thank you
Konstantinos
dinosgr
Still on waiting.
Hi Konstantinos
The PRIME version of Octane does not support the LiveDb. However the LocalDb should still work. Can you show some screenshots that demonstrate the problem?
dinosgr
Ok got it, only blender and daz light wave unity and unreal have full functioning 1 GPU prime licence.
But believe me when I say even the local db do nothing,as of screenshots they show nothing,you press import and nothing happens, so nothing to see there
Anyway, octane prime local and live databases works fine on all programs who have prime support.
Anyway thanks for your time.
I stay with blender
Thank you
Konstantinos
Thanks Konstantinos
The Modo PRIME plugin should support all Octane Prime features. If I click the "Import" button on the OctaneRender panel, I get the "Octane DB" panel showing with the LocalDb and LiveDb tabs (the LiveDb tab is disabled). So this appears to be working for me. The LocalDb tab should display all the materials that appear in Octane Standalone or other Octane plugins.
dinosgr
Anyway, i can't let this drop so here is the official page: https://home.otoy.com/render/octane-render/demo/#prime
Those are the specs for Prime license, and there is no mention of on-line database limitation.
I think you are missleaded from old post in forums, maybe you need to reconsider or ask official channel.
OctaneRender® Prime (Free Tier | CUDA)
Free for personal & commercial use
Terms and Conditions apply
Product specifications:
Use of the software is available only while online, connected via the internet to the OctaneRender licensing server
Only a limited sub-set of plugins are available (see above)
OctaneRender Standalone is not available in the Prime tier
OctaneRender Offline USB Dongle is not supported
A maximum of 1 GPU is available for rendering
Network rendering is not available
My apologies - you are correct - the Prime version of the Modo plugin DOES include the LiveDb. This must have changed at some point without me catching it. You can see in the Modo plugin you can select a LocalDb or LiveDb material, however the Import option does not work. I will ensure the LocalDb and LiveDb are working in the next release of the plugin.
Return to “Foundry Modo”
