OctaneRender 2025 for Modo [OBSOLETE]
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender 2025 for Modo - TEST and STABLE release.
SOLUTIONS TO COMMON ISSUES
  • Make sure your NVIDIA drivers are up to date.
  • Refer to the Troubleshooting section of the manual at https://docs.otoy.com/ModoH/ModoPluginManual.htm#Modo/Troubleshooting.htm
  • Cuda error 999 - failed to load shader code: Multiple definition of 'cpSptStatistics' in 'cuda_teturemode' means that your plugin version is too old for the Nvidia drivers that are installed, so update to the latest version of the plugin.
  • The Octane Greyscale Vertex Attribute is not working for a mesh : make sure Kernel->Render Cache is disabled, and Live Geometry is enabled and Load Cage is disabled for the mesh.
  • How do I copy Meshes between Modo scenes? Please see viewtopic.php?f=34&t=75794&p=389534
Modo Version
Windows : Modo15, 16 and 17 on Window 7, 8 or 10 64bit
OSX : Modo17 on macOS Somona, and only on Apple Silicon
Linux : Modo15, 16 and 17 on 64bit Linux
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 452 or higher on Windows, 450 or higher on Linux.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using.
Support Issues
If you have a support issue, pls provide the following information:
- Modo version
- OctaneRender for Modo version (ie. 2.0.10.16), and if it is PRIME or STUDIO
- Operating System (ie. Win XP, Vista, 7, 8)
- Amount of RAM
- Graphics Card(s) - model (ie. GTX 580, 3GB)
- Nvidia driver version
Prior to reporting issues, please try Modo->System->Open User Folder->Shutdown Modo->then delete the MODO[version].CFG file and restart Modo.
The most important part of resolving a problem is me being able to re-produce that problem. So pls provide as much detail as possible in order for me to do this, and if the problem is specific to the scene, send me the scene.
For more information
- Read the on-line manual, including the FAQ, Troubleshooting Guide and Limitations sections
- Watch the video tutorials at viewtopic.php?f=34&t=59793
- Watch the video tutorials at https://www.youtube.com/channel/UCRCItLUW7oheOp5vCGgkCCw
- Watch the amazing PixelFondue videos at viewtopic.php?f=34&t=59793
- Post your question on this forum thread
Download Links
Important:
  • When the Studio+ version of the plugin is installed, you must disable the Prime version of the plugin when comes with the Modo17 installer. To do this delete the modo\extra\Scripts\OctaneRenderForModoPrime folder from the Modo executable folder.
  • To install the PRIME version,
    1) If you have set the NEXUS_KITDISABLE environment variable to OctaneRender_Prime, delete this environment variable
    2a) On Windows, delete the C:\Program Files\Modo17.1v1.202577\modo\extra\Scripts\OctaneRenderForModoPrime folder
    2b) On macOS, delete the OctaneRenderForModoPrime folder from the Modo17.1 application Contents->Extras->Scripts folder
    2c) On Linux, delete the ~/Modo17.1v1.251515-Release/modo/extra/Scripts/OctaneRenderForModoPrime folder
    3) Install the OctaneRender for Modo PRIME version of the plugin
    4) Ensure you have OctaneRender_Prime plugin DISABLED and the OctaneRender plugin ENABLED in the Modo->System->Kit Toggle Enable menu
  • On macOS, when the 'Octane Improvement Project' dialog shows, press the Enter key to bypass the dialog box.
Current STABLE build (Octane 2025.5)
Current BETA build (Octane 2026.1 Beta 2)
  • IMPORTANT - Because Octane 2025.5 and Octane 2026.1 contain some changed nodes, new pins, etc, swapping a scene between each version is going to result in loosing some Octane data (particularly IRO and Anisotropy), so if you are going to use both, I suggest keeping both a 2025.5 version of your .lxo and a 2026.1 version.
Previous STABLE build (Octane 2025.4)
Release Notes
2026.1.0.209 (21-Nov-2025)
- Compiled with Octane 2026.1 Beta 2 - see viewtopic.php?t=85251 for details
- 2026.1 features IN this release : Vectron changes, Gaussian Splats, AOV's (partially), Displacement, OpenPBR surface material node.
- 2026.1 features NOT IN this release : MaterialX, LOD Data, CMYK Halftone texture.
- IMPORTANT: IOR and Anisotropy for all materials are now a texture inputs rather than a float, so scenes from previous versions of Octane will loose their IOR and Anisotrphy settings. This applies to the Glossy, Specular, Hair, Metallic, Universal and Specular Materials, and the Metallic and Specular Layers
2025.5.0.209 (21-Nov-2025)
- Compiled with Octane 2025.5
2025.4.0.208 (16-Oct-2025)
- Compiled with Octane 2025.4
- This version should work with macOS Tahoe
2025.3.0.207 (7-Oct-2025)
- Added LocalDb and LiveDb support for the PRIME version on Windows
- This release uses a new build pipeline, so installer filename have changed to be consistent with other Octane plugins
2025.3.0.206 (11-Sep-2025)
- Compiled with Octane 2025.3
- Resolved issue where texturemaps edited outside Modo were not automatically updating in the Octane Viewport
- Fixes to the "Realistic lens camera"
- Added a button for the Unfold command to the Material Tools panel
2025.2.1.204 (29-Jun-2025)
- Compiled with Octane 2025.2.1
- Added experimental support for Analytic Lights for Modo Point and Area Lights. Tick the Octane->Analytic Quad Light or Analytic Point Light to enable Analytic Lights for these Modo lights
- Fixed a number of minor issues related to the Realistic Lens Camera
- Fixed issue where the 2d Transformation node was missing it's property sheet
- Fixed issue where the Texture Layer->Texture was missing it's property sheet
- Added the Geometry->Mesh Volume SDF node, which allows an OBJ file to be loaded and treated as a Vectron object
2025.2.0.203 (20-Mar-2025)
- Fixed issue where the Spotlight Distribution texture could not be plugged into the Modo Directional Light "Distribution" pin
- Changes related to Octane 2025.1....
- Added the "UV coordinate with transform" node
- "Ray Step Increase Factor" pin has been added to the Medium nodes
- Updates to the "Chaos texture" node
- 11 New blend modes for output AOV layers
- Changed the maximum and default values for all kernels for "Parallel samples" and "Max. tile samples" pins.
- Added the "Camera mask" render pass
- Added option to the "Metallic Reflection Mode" pin of the "Metallic Material" node
- Add the "Pre-multiplied Alpha" pin to the "Output Aov"->"Blend"->"Texture" node
- The "Realistic lens camera" has been added - however the Aperture cannot be set by the plugin, so the FOV does not match with Octane. I am working with OTOY on a solution
- Added the Geometry->Vectron "operators" and "primitives" nodes. To use these, add a Modo Mesh item to the scene, click the "Add Mesh To Schematic" button and plug these vectron nodes into to "Octane Geometry" pin
- Not Implemented: Decals
- Not implemented: Mesh Vertex Rest Positions
- Changes related to Octane 2025.2....
- Added new Render AOV -> Alpha node
- Added a new pin Denoise Quality to the Camera->Imager and Output AOV->Open Image Denoise nodes
- NOTE : There have been changes to the Octane Image Tiles node, so can users that are using this note please test that it is still working as expected
- NOTE : The next release will fix the issue where the 2D Transformation node is missing it's property panel in this release
I have updated the installers at the top of this thread with:
2025.2.1.204
2025.3.0.207
2025.4.0.208
I have updated the installers at the top of this thread with both Octane 2025.5 and Octane 2026.1 Beta 2 builds:
2026.1.0.209
2025.5.0.209
I have added Linux builds to the above installers for 2026.1.0.209 and 2025.5.0.209.
I have posted the Octane 2026.1 build of the plugin tohttps://render.otoy.com/forum/viewtopic.php?t=85320
There will be not further Octane 2025 plugin builds.
Return to “Foundry Modo”
