Octane Volume updates - Range Remap, Composite Channels
neonZorglub
(Available from version 2025.3 - 16.08 / 2026.1 - 26.02)
---------- Range Remap mode -----------
Octane Volume normally uses the specified VDB file as 'Filename mode'
This simply send the VDB filename to the Octane engine, and the engine will get data from the specified channels (Absorption, Emission, etc), and scale those with the matching scale values (Absorption scale, Emission scale, etc..).
In some case, the scaling is not enough as the data may contain low values that create noise, or you may wish to eliminate too low or too high values to adjust the final result.
The Range Remap mode allows to remap the channel values more precisely, and to ignore values outside a specified range.
This can result in a more crispy effect, with full black around the fire/smoke/etc.
When enabled with the 'Enable Range Remap' checkbox, this mode will read the VDB channel data and re-create all volume data, and send it to the Octane engine.
For example, if a VDB has a temperature channel in the range [300,2000], it can be re-mapped from [350,2000] to [0,1], and values bellow 350 will be set to 0 if the 'Zero min' option is enabled.
The Old Max value can also be set lower than the actual data (for example 1800 would set all values higher than 1800 to 1800, or 0 if 'Zero Max' is enable)
Use the 'Channel values' button to read all the grid values of the current channel, to see what are the actual lowest and highest values.
Setting the 'New Min', 'New Max' to [0,1] also help with the channel scale, that can remains around the 1.0 value, and the Volume Medium settings can also use Density, emission power etc with values around 1.0 instead of very small values like 0.001 .
Samples:
OctaneVolume_Range_Remap.zip
(10.06 MiB) Downloaded 106 times
--- Sample :
Range_Remap\fire25_10_NoRemap_vs_remap_mx18.max
2 volumes objects, using the same VDB file.
Note that with no remap (OctaneVolume_001), Absorption scale is set to 0.001 and Emission scale to 0.002
This is to reduce the temperature channel values (range 300,2000)
The medium used (Map #3_NoRemap) has a Texture emission (Map #4_NoRemap) with Power set to 0.46
With remap (OctaneVolume_002), as the range options is set from [305,1892] to [0,1], Absorption and Emission scales are set to values around 0.5.
And the medium used (Map #3_remap) has a Texture emission (Map #4_remap) with Power set to 100
--- Sample:
Range_Remap\fire25_11_vdbs_vs_Phx_mx18.max
The PhoenixFD modifier has the same remap interface as the OctaneVolume.
The remap range for PhoenixFDFire001 is set the same as OctaneVolume_002.
Both use the same volume Medium.
Note that only Phoenix frame 21 (PhoenixFDFire001_0021.aur) is provided.
---Sample: Color gradient.
OctaneVolume_Thruster_ColorGradient.zip
(54.5 MiB) Downloaded 131 times
By remaping the range of a fire simulation, we can remove the surrounding turbulence, and keep the center of the fire to simulate an engine thruster.
Remaping to a [0,1] range makes it more easy to apply a color gradient:
Note that the Emission scale is animated to simulate an engine power variation.
thrusterAnimOut.flv
(302.44 KiB) Downloaded 84 times
--------- Composite Channels -----------
The composite channels mode can combine 3 single float channels to a vector3 channels.
There are 2 vector3 channels that can be created this way, named '_vec3_1' and _vec3_2'
This is specially designed to be used with the 'Std Volume medium', that can select those vector3 channels for Emission, Scatter, etc..
The typical use case is for RGB color channels, when they are only available as separate R, G and B channels.
Another usual vector3 channel is the velocity, but the Octane Volume already has an option to select velocity as 3 separate channels (x,y,z), or a single vector3 channel, so there is no need to use this Composite mode for velocity.
To use the composite channels, make sure 'Enable Range Remap' is turned on in Range Remap Settings
Samples:
OctaneVolume_RGB_Channel.zip
(20.71 MiB) Downloaded 99 times
Volume_composite_RGB_emission_mx18.max
The VDB used has 3 channels for the color: one for each color components : ColorR_phx, ColorG_phx, ColorB_phx.
Those 3 channels are set in the 'V3 channel 1 (x,y,z)' parameters, so the combined vector3 channel is available as '_vec3_1' in the Map #13 medium (Std Volume medium).
Note:
Those VDB files have been created with Phoenix FD, with RGB channels.
(specifying .vdb in the output rollup: Simulation Cache Save Path: $(scene_path).vdb)
See the related post 'Phoenix FD Fire color channel' : viewtopic.php?t=83095
The resulting VDBs have the up axis as Y instead of Z, so the OctaneVolume object has been rotated to compensate.
(There may be some options in Phoenix FD to export with Z as the up axis..)
Volume_composite_RGB_scatter_mx18.max
In this case, the combined rgb channel '_vec3_1' is used as the 'Scatter color channel' of the Std Volume medium.
---------- Extra channels (Std Volume medium) ----
A set of 5 extra channels can be specified, in addition to the 4 channels assigned to Absorption, Emission, Scatter and Velocity.
This ensure that those channels are loaded and selectable by the Std Volume medium for any of the medium effects (Density, Scatter, Transparency, Emission, Temperature).
--------- Motion blur enabled -----
When a velocity is specified and the current camera has Motion blur enable, the volume grid will have a motion blur effect.
This can be disabled / enabled with the 'Motion blur enabled' checkbox (when not using the Remap mode)
See the post bellow for samples with Range Remap mode and velocity.
Sample:
OctaneVolume_MotionBlur.zip
(27.48 MiB) Downloaded 116 times
----- Display settings ------
The settings to display the volume channels in the 3dsMax viewport is now per channel.
This allow to match the Remap values per channel (eg set Cell value min / max same as Old Min / Max).
Different Display percent and step count can also be set for each channel.
Note that the cloud point data used for the 3dsmax viewport display are stored in cache files.
The location of those cache files can be set in Render settings / Support / Common Scene Collection Settings.
The default location is in the same folder as the vdb files, in a sub folder 'OVdbPreview' : 'VDB Preview cache location' : 'VDB sub folder'
A new location type, 'Scene sub folder' can be used instead, if you wish to use different display settings using the same VDB files with different scenes.
---- File sequence updates ----
Issues with some filenames have been fixed.
Filenames with multiple extensions is now correctly handled (eg PhoenixFDFire001_0000.aur.vdb)
The 'Sequence digits' is automatically changed to avoid incorrect settings and allow the use of all available vdb files.
To disable animation, the value 0 should be typed instead of using the arrows (as the value 1 is usually re-set to 2 or more).
remKa
Thank you neonZorglub, it's working waaay better now !
Motion blur not working with the remap is a big topic though, will it be corrected with the next release ?
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
neonZorglub
remKa wrote: Fri Sep 12, 2025 7:55 am Thank you neonZorglub, it's working waaay better now !
Hi remKa,
In fact, remap with velocity works fine: I might have forgot to enable camera motion blur !
Here are some samples:
Volume_MotionBlur_Remap.zip
(51.42 MiB) Downloaded 104 times
VdbVelo_3_floats_Remap_mx18.max
This sample is using Range Remap and velocity for motion blur.
In current version, the 3 velocity channels x,y,z need to be set in the Combine channels first 3 slots, to use velocity as a vector.
The '_vec3_1' channel should be available in the 'Velocity XYZ' selector.
(if it appears as '[n/a] _vec3_1', you may need to refresh the dialog by deselecting and re-selecting the volume object)
Make sure the camera motion blur is enabled, and adjust the Shutter time while rendering in Octane Viewport, to check the volume motion blur effect.
As the velocity values might not match the scene scale / import 'Units', you can start with a high value for Velocity scale (eg 100.0)
See the same volume without remap, VdbVelo_3_floats_noRemap_mx18.max:
The 3 velocity channels are set in the 3 velocity slots, and Velocity XYZ is set to '(Use ch. X, Y, Z)'
Note that some artifacts appear on the borders of the grid.
Those cells have the lowest temperature (300) but that is not zero, so it's affected by the velocity of those cells, that are also not zero.
Using the remap mode with 'Zero min' ensure that those cells are set to 0, and won't be affected by the velocity.
Known issues:
-VDB files with single velocity channel as a Vector3 can not be used with Range Remap.
Note that Phoenix FD creates VDBs with 3 separate channels, so that will work with remap.
-The 'Motion blur enable' is not used in Range Remap mode.
To disable motion blur, set the Velocity XYZ to '(no velocity)', or Velocity scale to 0
remKa
I will check that, thanks :)
Return to “Autodesk 3Ds Max”
