OctaneRender™ for Blender 2025.3 - 30.7 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Updated to Octane 2025.3
  • Updated to Blender 4.5.2
  • Re-enabled feature "Release Octane License When Exiting" again
FIXES SINCE LAST RELEASE
  • Fixed Issue: Show Emitter option fails when an animation is rendered
  • Fixed issue of "Use Particle as Octane Sphere Primitive"
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2025.3 here:
viewtopic.php?t=84843
1. OctaneRender™ Server
Windows
Blender Octane Edition - 30.7.0 (4.5.2)
Octane Server - Studio+ Edition - 30.7
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
