OctaneRender for HoudiniSolaris 2025.2.1.1 [OBSOLETE]
BK
OTOY® is proud to announce the availability of the new DCC plugin OctaneRender for HoudiniSolaris 2025.2.1.1 release.
The world's fastest unbiased GPU rendering engine on CUDA and Metal now integrates completely with Houdini 19.5, Houdini 20.0 & Houdini 20.5 Solaris.
OctaneSolaris builds supported by this release: 19.5.805, 20.0.896, 20.5.584, 20.5.613, and 20.5.654.
What is OctaneRender for Solaris?
The OctaneRender for Solaris plugin is based on Pixar’s USD (Universal Scene Description) and Pixar’s Hydra API to empower artist workflows across look development, scene layout, lighting, and final rendering.
Pixar's USD pipeline
https://renderman.pixar.com/stories/pixars-usd-pipeline
-Installation steps-
Insert the OctaneRender® plugin folder path to the houdini.env file. Houdini®creates this file after launching it for the first time.
On Linux and macOS® systems, append a single line to enable OctaneRender®:
HOUDINI_PATH = "/path/to/octane;&"
On Windows® systems, you need to set the PATH to point to the plugin bin folder as well:
PATH = "C:/path/to/octane/bin;$PATH"
Setting this environment variable outputs any error related to loading the OctaneRender® plugin on the command line for diagnosing installation problems:
HOUDINI_DSO_ERROR = 2
-Houdnin Packages/json installation steps-
- Please create a folder inside Documents\houdini19.5 and name it as Packages
- Open notepad or any text editor and use these lines
    "enable": true,
    "env": [
            "OCTANE_AUTOSPAREPARAMS": {
                "value": 1
            "OCTVERSION": "PATH_TO_OCTANE_SOLARIS_Win64 FOLDER"
            "HOUDINI_PATH": {
                "value": "$OCTVERSION"
            "PATH": {
                "value": "$OCTVERSION\\bin"
            "PXR_PLUGINPATH_NAME": {
                "value": "$OCTVERSION\\dso\\usd_plugins"
- Then Save as OctaneSolaris.json
- Please make sure to disable the .env paths
- Please run **createPackageFileForOctane.bat** for automatic Package installer for Windows OS.
New features
To learn more about the new features and improvements of OctaneRender 2025.2.1 and the Render Node app, please check out the 2025.2 release post
Change log since last release
* This release syncs with our regular plugin.. More builds coming up with bug fixes in later releases!
Note: Click the link below to refer to the Important SOP to USD attribute conversion
https://www.sidefx.com/docs/houdini18.5/solaris/sop_import.html
Important notes:
[*] The minimum NVIDIA driver version required has been raised to R528 (R572 for GeForce RTX50 Series).
[*] The GPU version of Open Image Denoise is supported on Volta and Ada GPUs currently. The CPU version is used on devices with other models, and on macOS..
[*] The minimum version of macOS required is 14.5.[/b]
Linux Note
On Linux only default Houdini builds are supported.
This means that for Houdini 20.0 and 20.5, gcc11.2 builds are supported, and for Houdini 19.5, gcc9.3 build is supported.
Subscription Studio+ Downloads
OctaneSolaris [macOS](Link)
OctaneSolaris [Linux](Link)
OctaneSolaris [Windows](Link)
Demo Downloads
Happy GPU Rendering !!
Your team
OTOY
Kind Regards
bk3d
galleon27
Tiled render is bugged. Its rendering the tiles in the wrong positions.
Octane - Incorrect
Octane - Incorrect
Karma - Correct
Karma - Correct
Viewport screenshot
Viewport screenshot
itilestitch.zip
(11.46 MiB) Downloaded 128 times
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
BK
galleon27 wrote: Tue Sep 09, 2025 10:29 pm Tiled render is bugged. Its rendering the tiles in the wrong positions.
Hi galleon27 ,
Thank you so much for reporting this and for the sample file.
Its very helpful. We have created a bug ticket on our system to debug.
cheers
Kind Regards
bk3d
