OctaneRender™ for Blender 2025.2.1 - 30.5 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, and Linux versions. The download links, provided on this page, are for Studio+ License Holders
CHANGES SINCE LAST RELEASE
  • Updated to Octane 2025.2.1
  • Supported "import materials from Orbx"
FIXES SINCE LAST RELEASE
  • Fixed the wrong perspective image when "real lens camera" is used
  • Fixed issue that the Linux build misses the "Show Octane Viewport" button
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2025.2.1 here:
viewtopic.php?t=84843
1. OctaneRender™ Server
Windows
Blender Octane Edition - 30.5 (4.4.3)
Octane Server - Studio+ Edition - 30.5
ZIP PACKAGES (both distributives must be reinstalled, they depend on each other)
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX (Metal)
This is based on the Prime Edition for now. Full Studio+ versions for MacOS are still pending
DOWNLOAD
