The conversion of light sources is not correct
Elvissuperstar007
When converting from V-ray to Corona, all sources turn in the opposite direction, they shine in a different direction than in the originals, I have been observing this for half a year now
paride4331
Elvissuperstar007 wrote: Fri May 02, 2025 11:35 pm When converting from V-ray to Corona, all sources turn in the opposite direction, they shine in a different direction than in the originals, I have been observing this for half a year now
Hi Elvissuperstar007,
From Vray to Corona?
Regards
Paride
Elvissuperstar007
Corona and V-Ray light sources are not converted correctly into Octane Render — they appear inverted and emit light in the wrong direction.
They were shining downwards, when converted they started shining upwards and it's always like that
6072094.65a058df18752.rar
(77.15 MiB) Downloaded 76 times
paride4331
There's an issue that needs to be addressed, I'm sending my report to the developers. In the meantime, a workaround is to disable the 'Target' option in the Octane light settings after converting V-Ray/Corona lights.
Regards
Paride
HHbomb
you should take care of the doors normals. if you chamfer the doors choose smooth chamfer only.
Return to “Autodesk 3Ds Max”
