Quixel Plugin Patch for 3ds Max with OctaneRender Support
nagboy
So the official Quixel 5.5 plugin for 3DSMax doesnt work at all with OctanRender. Ive tried my best to make a version that works. Tested on Max 24/25. Works flawlessly for me.
Supports:
- All meterial types + geometry
- Sets correct colorspace
- Sets correct Gamma
- Sett correct scale
- Very polite implementation with one 2D transform / UV node for all textures
- Handles displacement correctly with both LoD according to map resolution and height.
Only dirty fix if the material is polished, then you may need to adjust the coating manually.
Instructions and files:
https://github.com/nagboy/OctaneQuixelBridge
glimpse
Thank You.
Will come handy for sure!
remKa
Oh thank you !
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
Return to “Autodesk 3Ds Max”
