Render Queue - c4d 2024.5.1 - Octane 2023.1.3
LFedit
I'm unable to get the Render Queue to use the "Render AOV group" output from the Render settings. C4d will only use what's in the C4d "save" tab, even though it's unchecked. Is there a workaround, or is this addressed in a newer version? Any help would be appreciated.
just tried with c4doctane 2023.1.3-R6:
https://render.otoy.com/customerdownloa ... R6_win.rar
And everything has worked as expected in Render Queue:
About, C4D Save tab, even if disabled, C4D always saves the results in Render Queue, it is a known c4d issue, common to any render engine.
ciao,
Beppe
LFedit
Thank you for testing Beppe,
I'm thinking something might be corrupt in my plugin install. I'll try reinstalling and see if the problem persists. No matter where I have the Render AOV group set to it will not render a file.
Ok, is it possible for you to try to merge the scene into a new one and rebuild the Render Settings from scratch?
ciao,
Beppe
LFedit
Thanks for the suggestion. I will try that next.
LFedit
I just updated to 2024.1.2 and the Queue is working again.
