Physical material conversion - transparency is lost
HHbomb
Physical material transparency is not converted. :-(
[edit] the transparency map...
paride4331
Hi HHbomb.
Actually, physical materials shouldn’t be convertible; instead, it’s the material standards that can be. Have you been able to?
Regards
Paride
HHbomb
Yes, you're right just basic settings are converted. Coming from Revit 3dmodel for quick tests opacity map could be usefull. :-)
Return to “Autodesk 3Ds Max”
