daylight analysis?
Dingbat
sorry if this has been asked before but is there an AOV that gives light values for daylight analyses?
something like in this:
https://www.youtube.com/watch?v=q3JI4rF ... yTck_5GQ6E (see around the 8 min mark)
or this:
https://www.youtube.com/watch?v=Tk4dOsqmcW0 (around 12:35 mins)
thanks
skientia
"light values" is ambiguous. There are a multitude of "light units" in their respective contexts.
None are natively available, and without going deep into "scientific" topics, perhaps the "False Color" (used on movie set and in post) is a viable alternative?
It is covered on this page (CTRL or CMD + F, "false color" to find it quickly).
Image Image
Octane resources
OCTANE POSTS (URLs have changed, which will break some links but all content remains available).
Dingbat
thanks for this
thought i'd seen this somewhere but couldn't remember where...
i managed to find another way to work it out that doesn't need these outputs so will use that instead.
skientia
It was predominantly known in Filmic (mostly known in Blender) but is also common in motion picture cameras.
What outputs are you referring to exactly and what other way did you discover?
Octane resources
Dingbat
actually this request has little to do with rendering final images. what i'm doing is demonstrating sufficient light levels for a Chapel conversion here in the UK
i started looking into it and what i found at first were light simulations with outputs similar to the ones above. there's specialised software to do it that calculate min/avg/total light levels and give data on other things needed for planning purposes
Octane i'm sure has all this data too, it's just not geared to extract and present it all so i was just checking if there was a way to do so
after i posted the OP i found that there are a couple of text books that the local planning authorities refer to for this, so I delved into those and there are some formulae that i can use (based on room size, sky visibility, glass transparency and so on) that will (hopefully) satisfy planning
