sorry if this has been asked before but is there an AOV that gives light values for daylight analyses?
something like in this:
https://www.youtube.com/watch?v=q3JI4rF ... yTck_5GQ6E (see around the 8 min mark)
or this:
https://www.youtube.com/watch?v=Tk4dOsqmcW0 (around 12:35 mins)
thanks
daylight analysis?
actually this request has little to do with rendering final images. what i'm doing is demonstrating sufficient light levels for a Chapel conversion here in the UK
i started looking into it and what i found at first were light simulations with outputs similar to the ones above. there's specialised software to do it that calculate min/avg/total light levels and give data on other things needed for planning purposes
Octane i'm sure has all this data too, it's just not geared to extract and present it all so i was just checking if there was a way to do so
after i posted the OP i found that there are a couple of text books that the local planning authorities refer to for this, so I delved into those and there are some formulae that i can use (based on room size, sky visibility, glass transparency and so on) that will (hopefully) satisfy planning
