Cinema4D version 2024.1.2 latest stable (17.12.2024)
bruce.chai
Hi all,
This is the plugin build based on OctaneRender® 2024.1.2 stable SDK. Any feedback will be much appreciated. Enjoy it!
This is the Standalone matching OctaneRender® 2024.1.2.
Some important notes about these builds:
The minimum NVIDIA driver version that is required by this version is 522. You can launch Octane with an older driver version, but it will fail to render and it will produce an error message in the log.
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models. On macOS, only the CPU version is supported.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
2024.1.2 plugin revisions
  • Fixed Render AOV crash that happens when a pin has no name
  • xparticles motionblur performance improvement
  • Fixed Volume nodes for 2024
  • Motionblur is completely turned off for ParticalGroupObjects as it is not supported
  • Proper torus in viewport for Vectron torus
  • Color of wireframe for other Vectron in viewport can be changed
  • Correct Vectron Prism's sides in viewport
  • Support Alpha to "Store Render Buffer" in LV
  • Fixed frame range in exported orbx
  • Fixed shadowstep on medium node
WINDOWS STUDIO+ 2024.1.2 (R21-R2025)
https://render.otoy.com/customerdownloa ... .2_win.zip
Mac OSX Prime 2024.1.2 (R25-R26/R2023/R2024/R2025)
https://render.otoy.com/plugindownloads ... .2_OSX.zip
Please note the macOS build below will only work correctly on macOS 14.5 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.4.0, R2025.0.2). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 522) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
ShivaMist
Does this mean that Cinema 4D particles are not natively supported?
DinoMuhic
Correct, Motion Blur on them is not supported yet.
While working on this issue a different problem was recognized so we had to push it to the next release.
However the render-time build-up when rendering X-Particles with Motion Blur was fixed instead.
Toche
DinoMuhic wrote: However the render-time build-up when rendering X-Particles with Motion Blur was fixed instead.
Hello,
Would it be possible to test this simple file and see if rendering times don't increase after the first 30 frames?
(I've tried on my own, and it's still increasing.)
Thx!
Test_Particle_Octane_MotionBlur_03.zip
(53.38 KiB) Downloaded 183 times
zantell1
cloud>export orbx works, but time=N seconds continues and freezes c4d (mac/osx). this was also in the last build
cjadams
Question I don't see the corresponding PC render node for this version.. and I get a mismatch for network rendering with the new 1.2 version.
what is the latest that works with both?
UPDATE IT IS HERE - viewtopic.php?f=24&t=84359
about X-Particles and motion blur, confirmed, the issue was not solved and needs to be revisited.
Sorry for the hassle!
@zantell1: sorry, the issue is not clear, please write to help at otoy dot com asking for Beppe, so I can investigate more deeply, thanks.
ciao,
Beppe
J.C
Hi, there there are differences in materials list. Octane window has them all but in C4D material manager there are missing some types:
System – Windows 11
Kalua
Thank you, team.
Weird to see a release on this plugin not done by Aoktar.
Is he still around?
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
cjadams
is C4d folks going to get any of the fun 2025/2026 preview builds?
