Render region works fine in IPR but if I do an actual render it says Octane doesn't support render region. I rarely use "Render" as opposed to IPR so I'm not sure if this is a bug or if its always been like this--although if it works in IPR, it seems like Octane supports render region?
Any possibility to get render region functionality enabled for a full render and not just IPR?
No Render Region?
- itsallgoode9
- Contact:
- itsallgoode9
- Contact:
Following up on this.
Hi itsallgoode9,itsallgoode9 wrote:Following up on this.
The RR for Octane is limited as the sampling is disrespected. Anyways its fast so we think its not required tbh.
As a workaround, we can set the Low sampling and do the full render.
cheers
Kind Regards
bk3d
bk3d
- itsallgoode9
- Contact:
what do you mean by "sampling disrespected"?
My specific use case example is when I'm spitting out a bunch of passes for a bottle render and one little line of text on a label needs to be updated. Due to having a bunch of render passes, I'd rather not manually save them out from IPR every time I'm updating the render. and since it's such a small section being updated, I'd rather not wait on a full 8500 pixel render of a glass bottle with caustics to update to noise free, which CAN take a decent amount of time.
I believe render region works in C4D, so was hoping we could get it in Maya too, if it was trivial to add.
Hi itsallgoode9,itsallgoode9 wrote:what do you mean by "sampling disrespected"?
Thank you for the clarification!
We were able to understand how our C4d plugin works.
We have logged a ticket to investigate this!
Cheers
Kind Regards
bk3d
bk3d
- itsallgoode9
- Contact:
great to hear, thanks!
