Cinema 4D R19 + Octane 2023.1.3 Not Showing up
TStudio
Hi Aoktar.
I have little problem here. I had to reinstall my Cinema 4d R19 after reinstalling windows 10.
Now when I install octane "OctaneStudio-for-C4D-2023.1.3" for R19 it does not appear in the Cinema. Can you help me with this issue?
Of course I have left only "c4dOctane-R19.cdl64" in folder as usual.
In recent builds of C4d like R20 - 2025 it works fine. Strange thing is that I can`t install any Octane plugin to my old R19.
It is not very urgent matter, since I work on C4D 2025 and octane 2024, but I want to have last stable Octane for C4D R19 installed when I stop subscription for C4d :-)
Thank you in advance.
Tomasz
Your R19 is older than requirements. Plugin cannot run if you don't use the minimum version numbers of C4D as described in release topics. R19.053 is minimum.
TStudio
Thank you!
So can you please tell me which is the last supported Octane for my R19 version ?
TStudio wrote:Thank you!
I can't because I don't know latest numbers. But it's not important, any number bigger than this will work.
TStudio
Thank you very much!
you need C4D R19.053 or greater.
But please note that 2023.1.3-R3 is the latest version you can install in C4D R19 or 20.
https://render.otoy.com/customerdownloa ... R3_win.rar
From 2023.1.3-R4, c4doctane supports C4D R21, or greeter only.
ciao,
Beppe
TStudio
Thank You very much. I new this :-) But your advise is much appreciated!
TStudio
I have reach out to Maxon support and they give me finlal R19.068 updater :-) Case solved! Octane is working - great as usual !
