Cinema4D version 2023.1.3-R6 (obsolete stable) 11.10.2024
Hi all,
This is the plugin build based on 2023.1.3 stable SDK. Any feedback will be much appreciated. Enjoy it!
This is the Standalone matching Standalone 2023.1.3.
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows.
Important: if using macOS, we strongly recommend that for macOS, you use at least 13.3 or preferably newer.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
2023.1.3-R6 plugin revisions
  • missing components on layered material > metal layer
  • Changed "Cloud" menu entries
  • Fixes on Vectron operators
  • UX revisions with unstable Cryptomatte types
2023.1.3-R5 plugin revisions
  • Fix: Temporal crash on vertex/color map usages
  • Fix: resetting the comment node on duplicate
  • Fix: missing material index when object doesn't have any UVW tag
  • Fix: missing color info for xpTrail+Displacer combination
2023.1.3-R4 plugin revisions
  • Fix: Parameter range/name for Bokeh/Aperture rotation in Camera tag
  • Fix: A crash on render instances when visibility of reference changed
  • Fix: Wrong material index when no UVW tags assigned or internally created on objects
  • Premultiplied Alpha setting in image sequence dialog needs to be set to none
  • Live-Viewer -> Save -> Change "Png" to "PNG"
  • Environment config file showing as editable textbox
  • "Force Tone-Mapping" checkbox is default ON for "Save Image Sequences" dialog in the LV
  • Null Material / Hair Material can't be edited in the material editor
2023.1.3-R3 plugin revisions
  • Added 2rd/3rd UVset support via UVW tags and texture projection nodes
  • Fix: Update issue for Instance Color/File mode on frame zero
2023.1.3-R2 plugin revisions
  • Fix for wrong start/end color for Octane Gradient
2023.1.3 plugin revisions
  • SDF mesh + materials supported
  • Initial support for C4D 2024.4's new particles, motion blur is not integrated yet
  • Some minor fixes, missing stuff on current features
WINDOWS STUDIO+ 2023.1.3-[R6] (R21-R2024)
https://render.otoy.com/customerdownloa ... R6_win.rar
WINDOWS STUDIO+ DEMO 2023.1.3-[R6] (R21-R2024)
https://render.otoy.com/plugindownloads ... R6_win.rar
Mac OSX Prime 2023.1.3-[R6] (R25-R26/R2023/R2024)
https://render.otoy.com/plugindownloads ... R6_OSX.zip
WINDOWS STUDIO+ 2023.1.3-[R5] (R21-R2024)
https://render.otoy.com/customerdownloa ... R5_win.rar
WINDOWS STUDIO+ DEMO 2023.1.3-[R5] (R21-R2024)
https://render.otoy.com/plugindownloads ... R5_win.rar
Mac OSX Prime 2023.1.3-[R5] (R25-R26/R2023/R2024)
https://render.otoy.com/plugindownloads ... 4D_OSX.zip
Please note the macOS build below will only work correctly on macOS 13.3 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.4.0). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
Audrey5110
This version is very slow for Cinema 4D 2024 .4.0
Please fix it as soon as possible. Thank you.
Audrey5110 wrote:This version is very slow for Cinema 4D 2024 .4.0
We don't have changes on our side to cause something like this. Not sure what kind of slowness and problem you have. Explain it please!
SSmolak
Thank you for new update !
Please increase Perf.timer(ms) max value to something like 5000 because it is really too low when C4D needs some time to update scene like updating hair object, instances or even changing hi-res HDRI map. Octane switch to 2x2 sub-sampling mode after that.
Is there chance to get Octane Scatter to work with noises in World Space instead of UV ? Every time main object is scaled or changed it ruins all instances settings :
auto-subsampling.zip
(1.28 MiB) Downloaded 263 times
Audrey5110
Hi aoktar
I know where the problem came from because I forgot to update the graphics card driver.
Thank you for everything you do. :)
DinoMuhic
SSmolak wrote:Thank you for new update !
That is a limitation in octane core. Nothing Ahmet can do about.
SSmolak
DinoMuhic wrote:That is a limitation in octane core. Nothing Ahmet can do about.
Yeah, "limitation" is very common word.
Octane Scatter works fine with Shader Effector which use noises in world space but unfortunately it works only for instances position, rotation and scaling but not for individual instance distribution using that noise - just like C4D Modify Clone option from effectors.
FxDesign
Thanks Aoktar, how do you get the color of particles in octane ?
FxDesign wrote:Thanks Aoktar, how do you get the color of particles in octane ?
Use "MoGraph color" or better one is to use "Instance Color" by assign fpGroup to that.
SSmolak
Thank you Aoktar for implementing sorting in Texture Manager ! But sorting size from high to low doesn't work correctly like incremental from low to high :
and sorting by filename sort not by texture name but by file path. Sorting by VRam usage would be good too.
It looks like switching texture type from normal to float do nothing in the terms of VRam usage but in LiveViewer there is difference.
This always show nothing :
Interface issue :
interface_issue.zip
(102.46 KiB) Downloaded 238 times
