shader mountain
pierres
Good morning
I have a quick question about the possibility of having a material that is applied depending on the gradient of a mesh
for my example it would be a mountain, I will be able to define the zones according to the slope. If you are flat, on a steep or gentle wall.
thanks
frankmci
Yes, use a FalloffMap node with the Normal vs Vector setting to define a gradient based on the Y Vector to Surface Normal ratio.
pierres
great thank you very much, it's perfect
larsgehrt
Hey, can you post an image on how you would setup the material?
I would love to know this one.
http://www.larsgehrt.dk / i9-13000k - 220 GB - RTX 4090
Return to “Autodesk 3Ds Max”
