convert material
pierres
Hello
Is there a solution to switch a scene with octane materials to a unity compatible scene?
THANKS
paride4331
Hi pierres,
The solution is to export the scene to .ORBX or export the geometry in the required format and then assign Octane materials (previously saved in Octane Render for 3ds Max in your localDB). However, I would recommend taking a look or asking in the Unity forum section for further assistance.
https://docs.otoy.com/3DSMaxH/3DSMaxPlu ... Export.htm
https://docs.otoy.com/3DSMaxH/3DSMaxPlu ... ocalDB.htm
https://docs.otoy.com/3DSMaxH/3DSMaxPlu ... terial.htm
Regards
Paride
Elvissuperstar007
I bought this plugin but haven't tested it yet, I don't work in Unity
https://www.scriptspot.com/3ds-max/scri ... verter-pro
To V-Ray from:
Standard (Default Scanline)
Corona Render (v7 or higher)
FStorm Render (v1.5.1c or higher)
Octane Render (2021.1.4-12.16 or higher)
finalRender (SE R3.5)
Arnold (basic)
Brazil_Advanced (RS v 1.2) material
NVIDIA iray (unofficial) material.
From V-Ray to:
Standard (Default Scanline) materials/maps
Corona Render (v9 or higher)
Return to “Autodesk 3Ds Max”
